2 members (Ponchogl, 1955 1 Series), 376 guests, and 4 robots.
Topics128,163
Posts1,057,044
Members48,463
DLBrooks
DLBrooks
For anyone with interest and is a fabricator. These I suspect work on 47-55 also.
http://67-72chevytrucks.com/vboard/showthread.php?t=797504
1959 GMC 100 Fleet
Follow in the DITY
The only gripe I have with that procedure is the use of that bolt-on wheel spacer. If I'm going to space a wheel out, I use a solid steel ring and longer lug bolts instead of using a bolt-on spacer. Most spacers are aluminum, and I just don't trust the idea of a lug bolt that doesn't tie the whole assembly together as a solid assembly. I have made round track race car caliper brackets by holding a caliper and pads onto the disc with air pressure and mocking up the caliper mounting brackets with heavy cardboard and an X-acto knife, then transferring the template pattern to a piece of steel and whittling it out with a Plasma cutter.
