3 members (Ponchogl, Otto Skorzeny, Hanks custodian), 104 guests, and 0 robots.
Topics128,134
Posts1,056,403
Members48,441
#1339547 12/29/2019 1:50 PM
When I acquired my 49 AD the fellow gave me what was left in the gallon can that was used when the truck was painted. I have gone on Shop-Lines website and did a search for some of the numbers on the side of the can that I can make out and nothing comes up. I was told the color is called Bright Red. I'd like to get some touch up paint made up this Spring but not sure of the number to tell the paint shop. Never had much luck when they use their little hand held scanner to check the paint color against their database.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
It showing PPG Industries. Try their website.?
I believe the WA7475 number is the factory gm paint code
1949 gmc 1-ton
My search shows that number for a 91 gmc color bright red
1949 gmc 1-ton
Think I may have found it. Looks like that color was used for a lot of years. Thanks fellows.
https://paintref.com/cgi-bin/paintdetail.cgi?ppg=3464
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
