| | | Forums66 Topics128,161 Posts1,056,956 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 34 Junior Member | | Junior Member Joined: Oct 2005 Posts: 34 | I've heard this is a common thought and question, looking for advice.
Have a '49 1 ton dually flat bed. Everything works fine but I want to use it as a work truck to tow cars on highway. Which is easier and better option; for value of truck, cheapest modifications and for coolness.
Swap entire body to say a 1977 C30 dually flatbed w/ 350? (considering this option because I need 6 new 700x18 tires. this will be close to $800. I know I can buy a good running C30 for that much.)
Or just swap out drive train (install 350, use original SM420, swap out rear end w/ new axle modern drums better gearing) and upgrade master cylinder? 2 possible draw backs; I'm not sure if I can upgrade the front brakes to disks or more modern drums, haven't seen any options for 1 ton or bigger, only 3/4 and smaller. And what wheels would I use on front to match rear wheels. What wheels can fit the 8 bolt pattern for 18' rims from '49?
Frank 1949 Chevy 3800 1929 Chevy International
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if it'll fit w/o too much grief, using the later chassis would be easiest, not necessarily cheapest, and would prolly up the value of the truck for resale if well done - would also be pretty cool to have the old look and the modern abilities, not to mention the ease of finding repair parts later
Bill | | | | | Joined: Jan 2002 Posts: 244 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 244 | I echo Red's reply. Not much work in fabricating body mounts and setting your cab and fenders on a later model chassis. But hey here's another way of building a classic tow vehicle  . PIC | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by f.booth: I'm not sure if I can upgrade the front brakes to disks or more modern drums, haven't seen any options for 1 ton or bigger, only 3/4 and smaller. And what wheels would I use on front to match rear wheels. What wheels can fit the 8 bolt pattern for 18' rims from '49? I want those 18" wheels. My plan is to cut the centers out and mount them in 16" or 16.5" rims. I don't want to deal with the 18" tires but love the look of the wheels. I'm planning a similar project. I have a P30 motorhome chassis that I plan to use. If you use the C30 stuff the front suspension is too wide and will give you some challenges. On a flat bed the rear axle width is not quite as big a deal. I've never seen a disk brake kit for a 1-ton but I have seen home built swaps that seem to work. You can mount disk rotors on your early hubs. Then all you need do is make a caliper bracket and you're set.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
