3 members (Otto Skorzeny, Rusty Heaps, Steelonsteel), 108 guests, and 2 robots.
Topics128,034
Posts1,055,536
Members48,425
#1338896 12/23/2019 11:48 PM
Hey everyone! Its been a while since I was on here last. I need the community's help here. I installed a GMC 270 with the SM420 into my 1948 Chevy 6100. After I installed the engine/clutch/xmsn; The clutch wouldn't engage/disengage the xmsn from the motor. I depressed the clutch pedal as far as its travel allowed and the motor still spun the xmsn with full torque. Any ideas?
I would guess you have the wrong throw out bearing assembly. I believe there are at least 3 choices. The type of clutch determines the correct length. That's true with the mid fifties and later, I don't know the details about exactly what fits the 48.
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
You probably have the clutch disc installed backwards. The center hub of the disc has several damper springs in it. The side of the disc where the damper springs stick out the furthest needs to go back inside the pressure plate. If the springs are installed toward the flywheel, they drag on the flywheel attaching bolts and don't let the clutch release fully.
Thank you! I bet that is what is wrong! I'm going to take it all apart tomorrow and check!
Thank you for the advice! I pulled everything apart. Turns out that I did have the friction disk in backwards. All is reinstalled in the proper orientation. Thanks!
Big Bolt Forum Moderator
glad it is resolved!!
Mike
