| | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | I have a fresh rebuilt Zenith 228 carb (model 11963 that orig came on the GMC 270) that I am ready to set on my stock-setup 261 to replace a junky non-tagged Rochester B. Looks fairly straight forward, but I have a couple of questions:
1. How do I need to set the idle screw? I believe I read in a manual to screw it all the way in, and then back out 1 - 1 1/2 turns. This carb does not have an adjustable main jet.
2. There is a vacuum adaptor, I assume used to connect to the spark advance. However, I am running an HEI distributor from a 250, and the vacuum line from the spark advance is plumbed into a large brass nut connected to the intake manifold. Do I need to plug the carb vacuum inlet with a bolt?
3. My carb doesn't appear to have a bracket for the hand-operated throttle cable. Not even sure how I would find one.
4. Anyone have pictures of a Zenith installed?
To me, this looks like about a 20-minute swap out, but I'm sure there's something I'm missing...
-Patrick 1953 Chevrolet 3100 261 / 4-speed / 4:11 / Commercial Red
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Try the idle mixture control screw at 1 1/4 turn on a fresh engine. Once you get 500 or so miles on the engine, should be able to get it down to 1 turn.
Hand throttle cable brackets are tough to find; since this is a non-stock application - make one, not that difficult.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Do I need to plug the carb vacuum inlet with a bolt?
Depends on: 1. does the carburetor have ported or full vacuum? 2. is this what you want? | | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | Panic: 1. I am not sure, how would I confirm? There is a very small hole on the bottom side of the base, where the carb sits on the insulator. Does that make a difference? 2. I figured a small bolt would work if I did not need the vacuum connection.
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Don't use a bolt.
Generally (not always) the threaded hole for vacuum is 1/8 pipe. If so, neat appearing 1/8 pipe hex plugs are readily available, if needed.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | The key is inside the bore. A small hole through the casting in the side of the bore: is it below the (closed) throttle disc? Or higher up in the bore? This determines whether the ignition gets a signal all the time, or only when the throttle passes a certain point. For stock engines both work well, but I favor "ported" (part time) with engines with any hot cam. | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Patrick, you're over-thinking this situation, as usual. Give me a phone call! Jerry
| | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | I always over-think, I'm just thankful I'm not the typical under-thinking millennial! The vacuum port is outside of shaft when the throttle flap is closed, and has a small vacuum hole on the bottom of the carb flange where it sits on the insulator. I'll give you a call Thursday Jerry, didn't want to bother you today, you're always such an enormous help for us amateurs
| | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | Turns out...
A Zenith 228 has a 2 1/2" hole spacing, and a 261 intake manifold has a 3" carb stud spacing. Jerry and I talked on the phone earlier, and I will weigh my options on an adapter plate, or selling the Zenith and buying a Carter that would feed enough air to my bored 261. I could slot the Zenith base holes 9/16" but I'd rather not do that...
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | The Zenith type 228 was made in SEVERAL DIFFERENT flange sizes.
Start with the correct size, and no slotting is necessary; PLUS the internal venturi will be closer to being correct for your 261.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | I thought I was starting with the correct size, being that it is a "11963" model number, which was used on the GMC 270, but I was unaware that there were intake manifold carb stud spacing differences between the 235 and 261 engines! There's always the "gotcha".
