| | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2018 Posts: 395 'Bolter | | 'Bolter Joined: Feb 2018 Posts: 395 | When I was in high school we ran a wire from the coil (can't remember which side) to the cigarette lighter. When the lighter was pushed in the coil was grounded out and the car didn't start. That was before the HEI. Will that same idea work with an HEI distributor? | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | On a real HEI, just ground the "tach" terminal, the one right beside the main power wire that goes to the distributor cap. Grounding a phony system like a Pertronix will probably kill it, too, but it probably won't ever start again. Jerry
| | | | | Joined: Dec 2002 Posts: 3,439 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,439 | I usually put a "kill" switch in line with the wire to the distributor. It will turn over all day, but won't start.
| | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | On a real HEI, just ground the "tach" terminal, the one right beside the main power wire that goes to the distributor cap. Jerry I had that issue on my HEI tach wire. I had the bright idea to use a short pigtail to that terminal on the cap for ease of attaching a tach for tuneups. Problem is, if the end of the dangling pigtail gets too close to ground, it will arc across and cause a poor running condition which will cause one to pull one's ear hair out trying to find out what's going on. It was during that adventure that I learned of how folks use that terminal as a kill switch. Carl
| | | | | Joined: Mar 2019 Posts: 202 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 202 | Why do you want a kill switch, as an anti-theft device?
-Kevin
This is what happens when you live with a house-full of women, the wife and daughters name all the cars: 1960 Impala - "Frankie" (Frank Sinatra) 1961 Apache - " 'Mater Jr." (wrecker) 1965 Corvair Monza Convertible 1967 C20 "Ol' Blue" (hidden in a log cabin for 30 years) 1972 SuperBeetle Convertible - "Juliet" 1976 SuperBeetle Convertible - "Olaf" 1988 Alfa Romeo Spider Veloce - "Romeo" | | | | | Joined: Feb 2018 Posts: 395 'Bolter | | 'Bolter Joined: Feb 2018 Posts: 395 | cool, thanks guys. I have a tach running of that plug, can I just splice another wire into that plug?
Kevin, yeah, thought it was a good idea to keep the simpletons from stealing it. In HS we thought we were cool. I'm just as cool today. Haha. | | | | | Joined: Mar 2014 Posts: 4,479 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,479 | A good anti-theft device today is a standard transmission.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2018 Posts: 395 'Bolter | | 'Bolter Joined: Feb 2018 Posts: 395 | | | |
