4 members (2-Ton, Ponchogl, Robert Crandall, 1 invisible), 89 guests, and 2 robots.
Topics128,037
Posts1,055,463
Members48,422
#1338645 12/22/2019 12:21 AM
When I was in high school we ran a wire from the coil (can't remember which side) to the cigarette lighter. When the lighter was pushed in the coil was grounded out and the car didn't start. That was before the HEI. Will that same idea work with an HEI distributor?
On a real HEI, just ground the "tach" terminal, the one right beside the main power wire that goes to the distributor cap. Grounding a phony system like a Pertronix will probably kill it, too, but it probably won't ever start again.
I usually put a "kill" switch in line with the wire to the distributor. It will turn over all day, but won't start.
Another quality post.
Real Trucks Rattle
I had that issue on my HEI tach wire. I had the bright idea to use a short pigtail to that terminal on the cap for ease of attaching a tach for tuneups.
Problem is, if the end of the dangling pigtail gets too close to ground, it will arc across and cause a poor running condition which will cause one to pull one's ear hair out trying to find out what's going on. It was during that adventure that I learned of how folks use that terminal as a kill switch.
Carl
Why do you want a kill switch, as an anti-theft device?
-Kevin
This is what happens when you live with a house-full of women, the wife and daughters name all the cars:
1960 Impala - "Frankie" (Frank Sinatra)
1961 Apache - " 'Mater Jr." (wrecker)
1965 Corvair Monza Convertible
1967 C20 "Ol' Blue" (hidden in a log cabin for 30 years)
1972 SuperBeetle Convertible - "Juliet"
1976 SuperBeetle Convertible - "Olaf"
1988 Alfa Romeo Spider Veloce - "Romeo"
cool, thanks guys. I have a tach running of that plug, can I just splice another wire into that plug?
Kevin, yeah, thought it was a good idea to keep the simpletons from stealing it. In HS we thought we were cool. I'm just as cool today. Haha.
Moderator, Electrical Bay
A good anti-theft device today is a standard transmission.
~ Jon
sadly
