3 members (Bill Hanlon, DadsFirstPickup, Otto Skorzeny), 75 guests, and 2 robots.
Topics128,154
Posts1,056,840
Members48,456
Cruisin' in the Passing Lane
Does anyone know the best method to use for restoring a plastic dome light lens? While searching for a good way occupy my time and still watch some College Bowl games in the garage, I decided to remove the interior dome light on my 54. As you can see from the pictures, everything appears to be original and in very good condition except for the exterior of the plastic lens. The inside of the lens is in remarkably good condition. The big blob of black goo connecting the braided wire to the red wire appears to be original as well. If it is not I am sure someone will let me know.
I thought I would start by wet sanding with some 400 then 600 then 1200 grit sandpaper to remove the 65 years of oxidation and then follow up on the buffing wheel with a polishing compound made specifically for plastic. This is a lot so I hope that I will still have something left when I finish. I also have a Turtle Wax Headlight Lens Restorer kit that I may use as well. It has a lens-sealing wipe to use if I am successful.
It is my understanding that the plastic lens was unique to the 54 and 55 1st series ADs and is not readily available or at least not that I could find.
This is my plan but I welcome any helpful suggestions.
Former owner of a 1954 3100 w/Hydra-Matic
"To know what you know and what you do not know, that is true knowledge." - Confucius
2 Offline
hi SmithLakeChevy,
i have had success restoring damaged headlights and other colored and clear lenses as follows (see the original radio dial in my radio restoration post)
under running water, wet sand with 600 until all damaged plastic is removed, clear plastic should make a milky white residue in the water, not yellow.
again with running water, wet sand with 1000-2000 to smooth the plastic in prep for compounding
use Meguiar's ultimate compound to work the plastic until it's clear, use a shop paper towel or kitchen towel, don't add water for this step
optional - finish with Meguiar's ultimate polish to get it better than original surface
if the plastic part will be in the sun it should get a UV blocking hard clear coat
i highly recommend U-Pol for a long lasting coating, it is used on modern automotive headlights.
if you are applying the U-Pol it is okay to skip the final polishing as the U-Pol will blend the surface anyway
the U-Pol spray can is not like regular spray paint, you will want to wear protective gear and be able to escape the fumes. It is nasty.
also i suggest you test it on an inconspicuous place for material compatibility.
use a metal instrument to put a dot onto the plastic edge, wait 48 hrs and check that it hardened and bonded well.
some plastics might react and go goo-ey and never harden due to negative reactions with the solvents and the cross-linking in the plastic.
hope this helps and best of luck
post photos of your progress
-stan
Insomniac
Insomniac
My lens had a crack in it. Bought a new one from Chevs of the Forties. The catalog shows complete units only, but I'm sure that I bought the lens only - call them if you are interested in a new one.
https://www.chevsofthe40s.com/detai...ht_Assembly_With_Lens_Like_Original.html
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Gord,
It looks like that Chevs of the 40s lens is glass?
47-53 were glass - I think the 54/55st were plastic?
Insomniac
Insomniac
The new one I bought is plastic - just like the original one. It was quite some time ago I bought it so perhaps they are glass now. If interested, give them a call; they might have some available but not shown in the catalog.
Gord 🇨🇦
Wow! This site never disappoints. Thanks Stan for the step-by-step detailed instructions. I hope this works and your plan sounds a lot better than what I had envisioned. Like Tim says, the 54 and 55 1st series trucks had plastic lens and I enjoy trying to preserve and save what I can on this old truck.
Gord, I appreciate the advice on the “Chevs of the Forties” site. I did check out that site, but I did not try calling. If this does not work out, I will be giving them and possibly others a call.
I will let everyone know how it turns out.
I finally finished the Dome Light Lens restoration this afternoon. I spent several hours wet sanding with the finer grits and then I finally had to drop down to a 220 grit wet sandpaper to get the plastic down to something I could live with. (I removed as much of the crazing and yellowing as I could with the 220 grit then I progressively worked my way back up to 400, 500, 1000, then 2000 grit to finish up.) I must admit, the toothpaste on the back of the sink started to look good as did the Old Dutch cleanser on the floor, so I used them as well during this long process. They seemed to help, or maybe it just felt like they helped. Did I mention there are no small projects, just the ones you think are small then take hours to finish. As you can see from the pictures below, I think the lens turned out nice though. It always feels good to preserve something original on this old truck.
Oh yeah, I finished up with the Meguiare’s compound and polish that Stan recommended and they worked out great using a Dremel tool and polishing attachment. I did not use the clear coat since the dome light is in the interior and I do not plan to leave the truck outside much.
As always, I appreciate everyone’s helpful suggestions. Who knows, maybe this will help someone else one day that decides to preserve one of these old plastic lenses.
2 Offline
that looks awesome, i also enjoy keeping original parts even if they aren't prefect.
i'm happy it turned out usable for you!
keep up the good work, it's only original once smile
-s
Awesome Grandpa
Awesome Grandpa
"It is my understanding that the plastic lens was unique to the 54 and 55 1st series ADs and is not readily available or at least not that I could find."
The 1954 Chevrolet truck dome light had a plastic lens (on all trucks, or, at least on Panel-Body trucks) and, a lower-power bulb (as used in all/some 1954 cars, I think).
Thanks Tim and Darthintel.
I never called call Chevs of the 40s like Gord suggested to see if they still have the plastic lens because I think the lens turned out pretty good. The finished picture above really doesn't do it justice. Just one small spec that may have been there from the factory. At least that my story and I am sticking to it.
Just put one of these in my 49. Nice but the light switch is reversed.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
Moderated by  ndkid275, Phak1
