4 members (tesa, Hotrod Lincoln, Wooley, baldeagle), 325 guests, and 3 robots.
Topics128,166
Posts1,057,092
Members48,463
#133858 02/18/2006 9:54 AM
Junior Member
Junior Member
My wife wants me to put an airbag into my 46. Fr some reason she does not like the idea of a steering shaft going thru my chest. If I am going to do this I might as well put on power steering. Any recommendations ofr a supplier?
Ted Wilson
#133859 02/18/2006 3:05 PM
It's not quite as simple as putting an airbag into your steering wheel.
There are sensors in the bum-er that measure deceleration which trigger deployment of the airbag.
There are all the electronic controls, as well as electrical connections.
And then there's the collapsible steering wheel with the airbag mounted in it that is unlikely to mount on your existing steering column.
You must also consider that airbags are one part of a safety system in a modern vehicle. That system includes crumple zones, a rigid passenger compartment, breakaway components, and so on. I think it's pretty obvious that your '46 doesn't have any of this modern safety innovations.
I truly believe that your best bet for an airbag is a balloon mounted to your steering wheel, the thicker the better. Perhaps one of those punch balls would work, although they are kind of large.
My female counterpart suggested an emergency raft mounted to the dash with a handle to pull for inflation. That will offer some protection for both driver and passenger.
No offense, but we both had a good chuckle at your (or your wife's) expense. We also believe your wife needs to learn a bit more before making such suggestions about how to improve your truck. I'd rate the project of putting safety airbags into your truck in the extremely difficult to impossible range, leaning to the latter.
Now, if you want power steering parts, any auto parts store will have the power steering parts (pump, lines, rack, etc.), but you'll have to do some re-engineering to make it work. There are other vendors that make a complete kit.
I'd check with Chevy Duty, LMC, No Limit and other vendors that have PS kits with all the compnents needed to fit in your particular truck.
Tilt your head back, cuz Mama Bird is going to ram a juicy nightcrawler of truth down your throat!
#133860 02/21/2006 4:39 AM
Air bags help, but they are designed for folks who don't wear seat belts.
First, install and wear good seat belts.
Second, if you are really worried, switch the steering column for a newer one that crumples in a collission.
#133861 02/27/2006 9:11 PM
Remember, that new veicles are designed to get crushed in an accident compared to the lead sleds of old. You can install racing seatbelts also. I have a 4 point set-up in my '54 from Crow Enterprises consisting of a Y shoulder harness (3 inch wide), a lap belt(3 inch wide) and an anti-sub belt(2 in. wide). I use the lap belt, the shoulder sits behind the seat, and haven't mounted the sub yet. After the headers and exhaust get updated I will probably be using the shoulder harness. I spent around $80.00 for it and they will customized to your specs.That's per side.I use that and the passenger uses the 3-point that the builder installed. Can't use a 3-point with corner windows. Check out my pics on the yahoo link.
1954 custom 1-ton (1 of a kind)
#133862 02/27/2006 10:11 PM
johno summed it up pretty well. A collapsible column, good seat belts and possilbly 4 whl disc brakes. I know accidents do happen (god forbid) but the chances are pretty slim depending on how much it's drivin. The chance off being rearended by a gawker is a lot greater.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
