5 members (Forty9, 3B, TPR57C, Otto Skorzeny, DennisM), 123 guests, and 3 robots.
Topics128,026
Posts1,055,403
Members48,422
#1338370 12/19/2019 6:20 PM
I recently finished up a complete rear brake drum rebuild. In no hurry to adjust and bleed at the moment. So, this GM 10 bolt axle/brake assembly under my '59 is out of a late model Camaro...year unknown. Over the past 2 to 3 weeks I have noticed small oil droplets forming on the garage floor directly below the spring perch to axle U-bolts (drivers side). At first it appeared like I had a brake line that had chaffed a hole....so I replaced in kind. Well, this oil spotting continues. Carefully, looking/wiping in and around the perch I see no visible sign of pooling oil. No evidence of a hairline crack along the welds at least on initial checks.
Note, the leaf springs are damp with contamination.
This is puzzling for sure. Have no intention of taste testing to see if it is in fact brake or diff fluid.
Apache1 #1338383 12/19/2019 8:26 PM
Crusty Old Sarge
Crusty Old Sarge
T Online: Content
If you place a clean sheet of card board under it over night you should be able to confirm the type of fluid. Gear oil will be dark brown to red, brake fluid will be yellow. It could be a small pin hole in the weld on your spring perch, just a thought.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Apache1 #1338384 12/19/2019 8:48 PM
Tasting is the only true way to tell. Lick it up directly from the floor to avoid contaminating it with cheeseburger grease on your fingers.
On a more serious note, check to see it it is gear oil is weeping from where a bracket was ground of during the rear end swap conversion. I had that happen to me on a 12 bolt. Gear oil will wick through the tiniest of passages.
Apache1 #1338390 12/19/2019 9:24 PM
The color directly on the finished concrete floor tends to be in the yellow range not brown/darker which would indicate gear oil.
I'm going to spray down with brake cleaner and do another closer inspection. Odd though that it migrated across the leafs on the springs.
Apache1 #1338391 12/19/2019 9:44 PM
Insomniac
Insomniac
Could it be that there's too much oil in the rear end? Just an idea - I don't know what happens when you overfill a Camaro rear end.
BTW, you can determine the year of your Camaro rear end by checking the numbers punched into the front of the axle tube as described here: http://nastyz28.com/2gcog/rearaxle.html#decode
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Apache1 #1338393 12/19/2019 9:56 PM
Have someone apply the brakes while you watch the area. Possibly spraying brake fluid under pressure from a small leak
1949 gmc 1-ton
Gord&Fran #1338395 12/19/2019 10:44 PM
It would be nice to know the year. Great info...thanks
Btw...I haven't added any gear oil.
Johnny N #1338396 12/19/2019 10:45 PM
That needs to happen. thanks
Apache1 #1338477 12/20/2019 5:00 PM
Brake fluid is water soluble. Gear oil is not.
Spray some water on the puddle to see how it reacts.
Apache1 #1338478 12/20/2019 5:38 PM
I didn't know that. So it acts just like metamucil. dang
Update, no signs of oil, on the floor this morning.
