1 members (Guitplayer),
85
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | I have a C65 eaton rear end with 7.17 gears that I'd like to stick under a trailer. But, I got to thinking that with 7.17's I might not be able to tow it very fast. What say you experts?
| | | | | Joined: Feb 2016 Posts: 1,997 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,997 | Pull the axle shafts out and fabricate some plates to cover the ends of the tubes, that way the differential won't be spinning.
| | | | | Joined: Nov 1995 Posts: 5,747 24601 | | 24601 Joined: Nov 1995 Posts: 5,747 | Or why couldn't you pull the axles out, cut the ends and bolt them back on?
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | Great ideas... i'll have to give this some thought.
| | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Just make sure the axle lube is full so the bearings are lubed as there won't be anything rotating inside the housing flinging oil everywhere. Mike B  | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | Does anyone know the top speed of a C65 with this gear ratio?
| | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Remove the axles, fab some cover plates for the hubs, and pack the wheel bearings with disc brake bearing grease. No need to run any lube at all in the center section that way. I'd also pull the center chunk and plate over the middle housing- - - -why haul all that extra weight around in the first place? Jerry
| | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | The rear under the trailer won't care how fast you pull it if it's just wheels on hubs. What type of brake system will it have? Mike B  | | | | | Joined: Aug 2001 Posts: 3,619 Moderator | | Moderator Joined: Aug 2001 Posts: 3,619 | Question about John's idea. Isn't there a axle bearing at the spyder gears? Is it part of the wheel bearing support system? If it is, I would just cut off the splines, put it all back together and make sure the axle is full enough to reach the bearings. As I remember, the ring gear splashes the bearings for lube. So your fill level plug may not be high enough to let the inner bearings get enough lube
Just some things to think about. Don
1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | Mike B. It won't need brakes, it will be under a pickup bed trailer and used to pick up rocks and make dump runs.
| | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | Keep it aimed down hill and loaded... Lol....It will go faster..  | | | | | Joined: Feb 2016 Posts: 1,997 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,997 | The heavy rear axles are call 'full floating' axles, this means that the axle shafts carry no weight, they only transmit torque. Fastest, least expensive would be cut the flange off and use it to re-seal the tube end. The hub bearing at the end of the axle carries all of the weight.
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | On a full-floating hub, the axles just provide torque. They support nothing. If nothing inside the pumpkin is turning it won't need lube. At some point axles like this had shafts with splined flanges to drive the hub. Then there was a light gauge cover held on with like 5/16 bolts. I don't know how late that system was used but if yours is like that pull the axles, grease the bearings and put the covers back on. You're done.
If you fill a pickup bed with rocks you'll need trailer brakes. What are you going to tow it with? If I understand what you're doing, you'll have to run regular 20 or 22.5 truck wheels to match the hubs with tires to match. In our state anything over 4,000 pounds has to, not only have brakes, but have a brake-away system too. There is made a "reaction brake" system commonly used on boat trailers (electric brakes don't like salt water). You could do a little figuring and come up with an appropriate-sized reaction-brake master cylinder, then plumb that into the existing brakes. I wouldn't pull such a trailer around without brakes. Even your spare Peterbilt tractor will skid the drivers with enough weight pushing it.
1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | yikes.. maybe no rocks!!
it turns out that this rear end will not work with the trailer that I have now. I think it weighs more than the whole trailer!
