3 members (HareCanvas, ArtA, papas52), 72 guests, and 3 robots.
Topics128,208
Posts1,057,452
Members48,471
I have a C65 eaton rear end with 7.17 gears that I'd like to stick under a trailer. But, I got to thinking that with 7.17's I might not be able to tow it very fast. What say you experts?
Another quality post.
Real Trucks Rattle
7
7 Offline
Pull the axle shafts out and fabricate some plates to cover the ends of the tubes, that way the differential won't be spinning.
24601
24601
Or why couldn't you pull the axles out, cut the ends and bolt them back on?
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Great ideas... i'll have to give this some thought.
Real Trucks Rattle
Just make sure the axle lube is full so the bearings are lubed as there won't be anything rotating inside the housing flinging oil everywhere.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Does anyone know the top speed of a C65 with this gear ratio?
Real Trucks Rattle
Remove the axles, fab some cover plates for the hubs, and pack the wheel bearings with disc brake bearing grease. No need to run any lube at all in the center section that way. I'd also pull the center chunk and plate over the middle housing- - - -why haul all that extra weight around in the first place?
The rear under the trailer won't care how fast you pull it if it's just wheels on hubs.
What type of brake system will it have?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Moderator
Moderator
2 Offline
Question about John's idea.
Isn't there a axle bearing at the spyder gears?
Is it part of the wheel bearing support system?
If it is, I would just cut off the splines, put it all back together and make sure the axle is full enough to reach the bearings.
As I remember, the ring gear splashes the bearings for lube. So your fill level plug may not be high enough to let the inner bearings get enough lube
Just some things to think about.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Mike B. It won't need brakes, it will be under a pickup bed trailer and used to pick up rocks and make dump runs.
Real Trucks Rattle
Keep it aimed down hill and loaded... Lol....It will go faster.. grin
7
7 Offline
The heavy rear axles are call 'full floating' axles, this means that the axle shafts carry no weight, they only transmit torque. Fastest, least expensive would be cut the flange off and use it to re-seal the tube end. The hub bearing at the end of the axle carries all of the weight.
1 Offline
On a full-floating hub, the axles just provide torque. They support nothing. If nothing inside the pumpkin is turning it won't need lube. At some point axles like this had shafts with splined flanges to drive the hub. Then there was a light gauge cover held on with like 5/16 bolts. I don't know how late that system was used but if yours is like that pull the axles, grease the bearings and put the covers back on. You're done.
If you fill a pickup bed with rocks you'll need trailer brakes. What are you going to tow it with? If I understand what you're doing, you'll have to run regular 20 or 22.5 truck wheels to match the hubs with tires to match. In our state anything over 4,000 pounds has to, not only have brakes, but have a brake-away system too. There is made a "reaction brake" system commonly used on boat trailers (electric brakes don't like salt water). You could do a little figuring and come up with an appropriate-sized reaction-brake master cylinder, then plumb that into the existing brakes. I wouldn't pull such a trailer around without brakes. Even your spare Peterbilt tractor will skid the drivers with enough weight pushing it.
1951 3800 1-ton
In the DITY Gallery
yikes.. maybe no rocks!!
it turns out that this rear end will not work with the trailer that I have now. I think it weighs more than the whole trailer!
Real Trucks Rattle
