5 members (greenie-reddy, frogfarmer, Gray_Ghost, 2 invisible), 315 guests, and 5 robots.
Topics128,156
Posts1,057,018
Members48,460
Hope this is in the correct forum. I am restoring a 1955 First Series Chevy truck and replaced the throttle and choke cables. When I installed the, into the truck, they are definitely longer than what was in the truck previously as they bend a lot under the dash before going through the firewall; and have a lot of cable left in the engine compartment before the carburetor. Is there an easy way to shorten these cables without ruining the integrity of the cables.
Pull the cable out of the sheath.
Run the cable to the bracket for a test fit for length.
Mark the sheath and cut it to the proper length.
Reinstall the cable into the sheath and run it through for a test fit and cut it to the proper length.
Thank you. What is the best way to cut the sheath?
Hacksaw, die grinder with a cut off wheel, lineman pliers...just remember to deburr it when done.
Also, it's a good idea to put a light coat of white lube on the cable when sliding it back into the outer sheath...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thank you very much. Will try this out.
