| | | Forums66 Topics128,152 Posts1,057,012 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2019 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2019 Posts: 22 | Hope this is in the correct forum. I am restoring a 1955 First Series Chevy truck and replaced the throttle and choke cables. When I installed the, into the truck, they are definitely longer than what was in the truck previously as they bend a lot under the dash before going through the firewall; and have a lot of cable left in the engine compartment before the carburetor. Is there an easy way to shorten these cables without ruining the integrity of the cables. | | | | | Joined: Mar 2010 Posts: 10,303 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,303 | Pull the cable out of the sheath. Run the cable to the bracket for a test fit for length. Mark the sheath and cut it to the proper length. Reinstall the cable into the sheath and run it through for a test fit and cut it to the proper length.
| | | | | Joined: Oct 2019 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2019 Posts: 22 | Thank you. What is the best way to cut the sheath? | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | Hacksaw, die grinder with a cut off wheel, lineman pliers...just remember to deburr it when done. Also, it's a good idea to put a light coat of white lube on the cable when sliding it back into the outer sheath... Mike B  | | | | | Joined: Oct 2019 Posts: 22 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2019 Posts: 22 | Thank you very much. Will try this out. | | |
