5 members (52Carl, klhansen, Otto Skorzeny, farmallb, rick46ia), 75 guests, and 13 robots.
Topics128,021
Posts1,055,354
Members48,420
#1337546 12/13/2019 9:55 PM
hello everyone finally got truck going im excited and love it. my 228 came out and a 235 went in. 228 was cracked. the 235 came complete out of 56 chev and had all rebuilt. went to put original carb on and doesnt fit . so used 235 carb. i want to install my old carb as then i have manual choke and throttle hooked back up.but carb hold down studs holes are closer together. has any figured out a method
i also have a exhuast and intake from a 235 truck motor from early 50 not sure what year but it has same spread on carb hold down studs as 56.will my old intake fir the head on my 1956 head. any help or ideas would be so appreciated, your truly, mike
mikebrou #1337555 12/13/2019 11:07 PM
You can get a 235 carb with Manuel choke and throttle.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
mikebrou #1337639 12/14/2019 5:02 PM
Riding in the Passing Lane
Ive seen them where someone cut a slot into the mounting holes & used a flat washer. You will lose power though.
George
1972 Chevy c10 Cheyenne Super
mikebrou #1337652 12/14/2019 6:08 PM
thankyou both. kevinski , thankyou i didnt know i could get a carb but do you know if it will hold the 228 oil bath as well where do i look, thankyou somuch
mikebrou #1337656 12/14/2019 6:45 PM
wrenchbender. im trying to visualize what you mean. i know my 235 mount are farther about then the carb off my 228. plaese help
mikebrou #1337711 12/15/2019 5:30 AM
Insomniac
Insomniac
GMC 228 intake/exhaust manifolds will not fit Chevrolet 235.
I don't think that elongating the holes on the 228 carb so it will fit the 235 intake is a great idea. George (Wrenchbender Ret,) said he has seen it done but he stopped short of recommending it. He said you will lose power.
So, I think you should live with the carb that came with the 235. If it's an automatic choke model you can get a manual choke conversion kit. Or, you can get another carb. If you want to get another carb, you might want to consider a Carter. There are knowledgeable members of this forum who will tell you that the Rochester is inferior to the Carter. There's plenty of discussion on this topic you can read - use the search feature.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
mikebrou #1337712 12/15/2019 6:26 AM
What year of truck do you have and I assume it is a gmc .I see you are from B/C ,the reason I ask is because if your truck is a Canadian model it may have had a 216 in it not a 228 .
"The Journey"
Follow in the DITY
mikebrou #1337747 12/15/2019 6:12 PM
gord thankyou for reply ill go with getting a manual conversion kit that you mentioned so appreciate you telling me about 228 manifold wont fit
mikebrou #1337751 12/15/2019 6:34 PM
kevinski, thankyou for reply. my truck is 1952 gmc bought in las angeles. i have all the paper for truck sense new. you right it was 228 and i had a cracked bloak my fault as well. made me sick.so started to look for a 228 before i found one i got busy for years . last year i turned 70 and thought if i dont do it now i may not get a chance. so got lucky found a 235 and went with it. had it rebuilt and went to install it found it 1.5 inches to short. this is when i found about usa gmc model trucks verses chev. i should have researched it more. got smart and found this forum which has been si much help form all you folks. trucks runs great drives nice im very happy. but i still want manual choke and throttle cable plus ability to use oil bath. mean while ill install manual choke kit gord suggested.im still looking for a 228 if i find a good one ill start over. just a matter of switching.
mikebrou #1338001 12/17/2019 1:40 AM
The Rochester carb for a 235 and oil bath air cleaner .Note the 235 carb is larger than a 216 carb they look the same but the measurement between the mounting studs are different
"The Journey"
Follow in the DITY
mikebrou #1338069 12/17/2019 2:36 PM
There are 2 different bolt spacing:
All 216 and early 235 2-11/16" (S.A.E. #2 flange)
Late 235 and all 261 2-15/16" (S.A.E. #3 flange)
mikebrou #1338111 12/17/2019 6:56 PM
ok my original carb is a 228 off a 228 number 11147. i longgated the holes to fit manifold.im going to give it a try. but if i read right i can buy same carter with a 3 inch spread bebween hold down bolts.ill see how it runs before a buy new carb . its 600 us thats 800 for me lol. ill hook gas line with rubber fuel lines to carb beofore i go through trouble of remaking both fuel line a nd vacuum.it was good enough for 228 cu in so do you all think it can handle 235 cu in.
mikebrou #1338112 12/17/2019 6:57 PM
panic do you have a 228 in your truck
mikebrou #1338155 12/17/2019 11:23 PM
235 Rochester b is around 310 Canadian at rock auto plus shipping . Don’t know if your oil bath air cleaner will fit from the 228 .
"The Journey"
Follow in the DITY
mikebrou #1338304 12/19/2019 3:21 AM
Crusing in the Passing Lane
Mikebrou,
GMC engines came in other displacements, if you are looking for another engine-236, 248, 256, 270, 302. They all look the same except the SN starts with the displacement, so one of these would fit your engine compartment, too.
Ed
