3 members (Shardean, Joe H, 1 invisible), 89 guests, and 2 robots.
Topics128,057
Posts1,055,814
#1337987 12/17/2019 12:45 AM
Hi Members. I’m upgrading my front drum brakes to disc brakes. I have a dual master cylinder. I did not have a proportioning valve in the old system so I purchased the kit with the deluxe disc brake kit. My question is does anyone have a diagram or a photo or instruction on how this is assembled to the master cylinder? Any help would be appreciated. A photo of the master cylinder and proportioning valve is attached. Thanks.
Insomniac
Insomniac
Looks like a CPP kit.
You should be able to find the instructions here:
https://www.classicperform.com/instructions.htm#1
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Thanks for the info but my kit looks very different. See photo on original post.
Insomniac
Insomniac
Looks like the same L shaped bracket to me. Well, if this doesn't help, you should ask your supplier for instructions.
https://www.classicperform.com/Instructions/PDF/4754MCA.pdf
Gord 🇨🇦
