3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#1337858 12/16/2019 3:03 PM
Has anyone adapted a speedometer cable bullet to an SM 420 tranny?
Thanks!
Saluki #1337876 12/16/2019 4:35 PM
Sorry about my ignorance, Saluki, but what is the "cable bullet"
Maybe you are referring to one of the "speedometer gears"?
"Speedometer gears include both a drive gear and a driven gear. The drive gear is located on the transmission's output shaft. The driven gear is positioned in a removable housing that is typically located in the transmission's tailhousing." (from TCXI automotive)?
Saluki #1337878 12/16/2019 4:45 PM
I think I now know what the "bullet" is, Saluki (I did a Google search).
I only know Stovebolt gears - I think the "bullet" is an integral part on one of the original gears?
I think that you need a gear set (drive & driven) that matches your drive-train gear ratio (and your transmission attachment hole). Someone will correct/clarify this, I hope.
Saluki #1337880 12/16/2019 5:12 PM
The bullet is the adapter part that goes into the transmission housing that you hook the speedometer cable into.
Sorry I was not clear. It is a newer version that holds the driven gear. I also saw on eBay (I think) an SM 420 driven gear housing that appeared to have a plastic gear instead of the old metal gear.
IF that is possible I could replace the drive gear and driven gear. I currently have a 4 tooth drive gear and a 13 tooth driven gear that is a bit too slow. So I either change the gears or get an adapter to speed it up.
Saluki #1337889 12/16/2019 7:05 PM
Insomniac
Insomniac
Earlier discussion on this: https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=921081
I'm interested in this subject. I have a piece of paper with the speedometer reading to the actual speed written on it; not convenient but it works.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Saluki #1337895 12/16/2019 7:55 PM
I have been using a GPS and I do understand the easiest thing to do is get a ratio adapter. I was just curious if anyone knew of a modification that I might also use.
With the number of 420 trannys out there I thought there might be another option.
Thanks for the link Gord&Fran, I also have a 54 1/2 ton.
If I knew what plastic gear would fit that old adapter, I would also change the drive gear. I could put in an 8 tooth drive gear and a 22 tooth driven gear.
Saluki #1337911 12/16/2019 8:59 PM
Insomniac
Insomniac
There seems to be lots of gears for automatic transmissions and the 4 speeds found in muscle cars. But we have the SM420...
I'm still not settled on the ring and pinion gears in our truck. We might make a change there so I'm not too anxious to get the speedometer reading corrected now. Plus, our speed limits are in Km/h so I'm kind of used to doing conversions in my head.
Gord 🇨🇦
Gord&Fran #1338674 12/22/2019 5:56 AM
I don't know if they are all the same but my speedometer is adjustable. Kind of trial and error but I was able to dial mine in pretty well.
