2 members (baldeagle, dunfire),
86
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13372 07/09/2004 4:29 AM | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Hi Guys, For about a week or so the starter has been making this slight "wheeee" sound when I let go of the key when starting the engine. Today I dropped the starter to bench test it. I hooked the starter up the battery with some jumper cables, and used a really big flat tip screw driver to spin it. It takes a few moments from a dead stop to get the starter up to speed, and is still pretty slow. The bushing on the end next to the teeth is flopping around on the shaft, and is not where it should. There's slack in the shaft(wobble), and when power is off it does make a "whoooooo" sound. I also have the starter off of the V8 I got that is also a manual trans starter that bolts up to the bell housing not engine block. THe only difference I see is the mounts, can I change the mounts, and have a good starter? :confused: I checked this one, it cranked over like mad, and is smooth like new. TIA, David
My truck don't leak oil, it just marks its teritory.
#13373 07/09/2004 4:53 AM | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | You can probably swap the nose cone, but you'll need to install a new front bushing before you do. Be careful to get the right "end play" on the armature, as it's critical for correct gear engagement in the flywheel. There should be a slight clearance front-to-rear on the armature, not a tight fit. It's adjusted by installing different thickness thrust washers at the rear of the starter if you need to change the clearance. Be sure the starter drives have the same number of teeth. A mismatch there could damage the flywheel, and then you've got real problems! Jerry
#13374 07/09/2004 5:37 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Check your private messages, I have an extra starter.
#13375 07/12/2004 7:38 PM | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Hi Guys, The other day I did alot of calling around to a bunch of shops, even the dealerships. None of them had a starter rebuild kit, or bushings for this starter.  :confused: So my Dad & I went to a AC Delco parts place in Manteca (north of town), and did pick up the bushings, retainer clip, and half of the spacer I was missing for $1.83.  About an hour later I was back on the road with a very fast turning starter that acts like it's on steroids. David
#13376 07/12/2004 7:51 PM | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | I forgot to mention that the guy at the counter said that some how the starter ate up/disentergrated(sp) the retainer clip ring, and half the spacer (at the tip of the drive end of the starter). :confused: David
#13377 07/13/2004 3:18 AM | Joined: Sep 2003 Posts: 23 Member | | Member Joined: Sep 2003 Posts: 23 | Cool deal on that starter. Is the Delco place on North Main Street? We used have them repair stuff for us when I was kid. I thought that place went out of business 30 years ago. I have a have generator that needs field coils and bearings. I will have to give them a call. | | |
#13378 07/13/2004 3:58 AM | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | There's a rebuilder in Nashville, TN. that specializes in all sorts of oddball stuff, including old GM starters, generators, regulators, etc. I found a set of brushes for the generator I used in my charging system tech tip article, for less than $5.00. (I've installed a bunch of them at a buck a set, but that was back when the labor rate was $7.50 an hour!) No website, but write or call if you've got a parts supply problem:
Todd's Auto Parts 206 N. 1st. Street Nashville, TN. 37213
(615) 254-6264, (615) 256-1477
No, I'm not on the payroll, so I'm NOT advertising! Jerry
#13379 07/13/2004 10:34 AM | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Originally posted by Task Force Dan: Cool deal on that starter. Is the Delco place on North Main Street? We used have them repair stuff for us when I was kid. I thought that place went out of business 30 years ago. I have a have generator that needs field coils and bearings. I will have to give them a call. Yes, they're still located on Main st. David
#13380 07/14/2004 5:32 AM | Joined: Sep 2003 Posts: 23 Member | | Member Joined: Sep 2003 Posts: 23 | Chevyboy 62,
Thanks for confirming the location. The old truck could use a run down to Manteca.
Hotrod Lincoln,
Thanks for another source.
Dan | | |
#13381 07/14/2004 5:55 AM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | Task Force Dan, there is a guy in Placerville that does this kind of work.............He re-wound my 6 volt generator to 12V, all I had to do was get a 12V regulator, battery and bulbs,etc. It was re-brushed and re-bushed at the same time. I don't remember how much it was; but I never had any trouble with it.
Jerry's Generator Service 3102 Blairs Lane Placerville, CA 95667 (530)622-6257
*** GMC ***
