1 members (JW51),
78
Mod | | | Forums66 Topics128,024 Posts1,055,390 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 61 | I am getting chatter when I push in the clutch, often goes away after driving a little bit. Truck will sometimes sit outside for weeks or days without being driven. Any ideas? Thanks! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | ya mean when you let it out to start movin? what I'd suspect is prolly a bit of crud on the disc and it's "sticky" when cool, quits grabbin when it warms up w/ use - if you can't live w/ it, hafta change the disc and resurface the pressure plate and flywheel - might also be a funky spring in the presure plate
Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Clutch chatter is when the clutch starts to engauge it shakes the vehicle like grabbing & releasing. If it makes a grinding noise & vibrates the pedal it is a faulty throwout bearing. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2004 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 61 | Thanks guys, I will check those out. | | |
