1 members (lumbersawyer),
84
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2018 Posts: 10 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 10 | I have a 1951 gmc 3/4 ton pickup with a 228 6 cylinder. what should I do about gas type. Is regular gas ok or do i need an additive? If so what . At present I am using MO gas (aviation gas with no ethanol). thank you | | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | I run 87 octane. It works very well.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | No ethanol is best but that comment usually starts a big debate. It’s been beat to death on the site. Do a Stovebolt search and be prepared for an evenings reading.
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | I run 87 octane. It works very well. Me too, running a '63 235 in my truck.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jul 2000 Posts: 2,191 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,191 | 87 octane gas (10% ethanol) purchased August 18. Drove it today - idled a bit rough - needed a bit more choke but it ran OK.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Apr 2005 Posts: 61 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 61 | My ‘46 gmc with its 228 likes 89 octane, NO ethanol gas. I drive a few miles into south Central PA to find it. For your area, check out pure gas.com Ethanol is a bad deal on many fronts, but once you dump it in your antique motor vehicle, nothing good happens. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Octane was way below 87 or 85 when our trucks were new. Whatever the lowest grade at the pump is adequate, anything. Higher is just a waste of money. No alcohol is best, 100 low lead adds more lead than we need, probably not legal if anyone is looking. 80 octane avgas, if one can find it, is OK.
NO alcohol is best.
Ed
| | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | Running on ethanol blend & leaving a rig to set with in in the system very different. The only non-ethanol you can by in Oregon premium / high octane so I run the 87 E10 but purge & put non ethanol in for the winter when rigs will only be run a few times.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 | Ethanol is hydrophilic - attracts water from the atmosphere - and shouldn't be used in vehicles that sit for prolonged periods. This is why ethanol gas is not allowed for use in aircraft. Here is a list of non-ethanol fuel sources state-by-state: https://www.pure-gas.org/index.jsp
1951 Chevy Panel Truck
