1 members (Gray_Ghost), 72 guests, and 0 robots.
Topics128,050
Posts1,055,761
#1337070 12/09/2019 6:04 PM
I have a 1951 gmc 3/4 ton pickup with a 228 6 cylinder. what should I do about gas type. Is regular gas ok or do i need an additive? If so what .
At present I am using MO gas (aviation gas with no ethanol). thank you
I run 87 octane. It works very well.
No ethanol is best but that comment usually starts a big debate. It’s been beat to death on the site. Do a Stovebolt search and be prepared for an evenings reading.
52Carl #1337127 12/10/2019 12:21 AM
Me too, running a '63 235 in my truck.
Craig
Insomniac
Insomniac
87 octane gas (10% ethanol) purchased August 18. Drove it today - idled a bit rough - needed a bit more choke but it ran OK.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
My ‘46 gmc with its 228 likes 89 octane, NO ethanol gas. I drive a few miles into south Central PA to find it. For your area, check out pure gas.com
Ethanol is a bad deal on many fronts, but once you dump it in your antique motor vehicle, nothing good happens.
Crusing in the Passing Lane
Octane was way below 87 or 85 when our trucks were new. Whatever the lowest grade at the pump is adequate, anything. Higher is just a waste of money. No alcohol is best, 100 low lead adds more lead than we need, probably not legal if anyone is looking. 80 octane avgas, if one can find it, is OK.
NO alcohol is best.
Ed
Running on ethanol blend & leaving a rig to set with in in the system very different. The only non-ethanol you can by in Oregon premium / high octane so I run the 87 E10 but purge & put non ethanol in for the winter when rigs will only be run a few times.
BC
1960 C60 pasture art
Ethanol is hydrophilic - attracts water from the atmosphere - and shouldn't be used in vehicles that sit for prolonged periods. This is why ethanol gas is not allowed for use in aircraft.
Here is a list of non-ethanol fuel sources state-by-state:
https://www.pure-gas.org/index.jsp
1951 Chevy Panel Truck
