1 members (5 Window 9434),
68
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2018 Posts: 80 Shop Shark | | Shop Shark Joined: Jul 2018 Posts: 80 | hi, this forum has been a great source for help and info and i thank all the folks who take the time to help greenhorns like me learn and continue the hobby.
i'm working on a 1951 panel that has a 1957 235. i've had the engine rebuilt using a mild cam, dual zenith 228s, edlebrock intake and fenton headers.
after running great for 500 miles, i noticed a ticking sound that is easy to hear on start up but gets quiter after about 2 mins. im still able to hear it once the engine warms up and it never goes away. my first thought was a exhaust leak so i brought it back to the muffler shop that built the dual exhaust....3 times. the noise is still there.
now, i'm new to this so i'm still learning. my thought was that it could be a valve/push rod adjustment but i have heard different stories as to wether the valves could be adjusted on this motor as it has hydraulic lifters.
the tick is clearley coming from the top of the engine. if they can be adjusted, what is the process.
thanks for any help that you experts can offer!
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | Valves can be adjusted. How they are adjusted is different depending on whether the cam is using hydraulic lifters or solid lifters. Do you know by any chance what kind of lifters are in your motor? Whose cam did you install? That might be helpful in determining what lifters you are using.
Mike
| | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | Ticking and clicking can be maddeningly hard to find and are often of no consequence unless they get worse over time. One trick is to pull the valve cover and check around each rocker, valve and pushrod with a length of 1/4 inch rubber tubing with one end stuck in your ear. Another trick is to use a long thin screwdriver pressed against your head behind your ear and probe around with that. DO NOT do this in the vicinity of the fan. You can also buy a mechanics stethiscope for the same use as the screwdriver. It's safer. The tube method can be used to probe around for possible exhaust leaks too. Check all along the head/exhaust manifold interface and, in your case, also check around the tubes that duct exhaust heat from the exh manifolds into the bottom of the intake manifold. Do this cold and hot. Mine started leaking after about ten years and required another turn on the fittings to tighten them. Check both down-pipe flange gaskets when cold and when hot. Ticking also comes up the throttle linkage to the gas pedal from the pivot on the side of the block. There is also the possibility of spark jumping from a plug wire to ground but that is usually associated with a miss on one or more cylinders. Good luck and happy hunting. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Try all the suggestions in your other thread on this subject in the Driveline Forum.
| | | | | Joined: Jul 2018 Posts: 80 Shop Shark | | Shop Shark Joined: Jul 2018 Posts: 80 | the lifters are hydraulic, the cam is a comp specs are: int exh av dur: 260 260 dur@ .050 212 212 valve lift .447 .447 | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | Give the valves an adjustment and see what that does for your tick.
Mike
