2 members (Ponchogl, Otto Skorzeny), 72 guests, and 1 robot.
Topics128,034
Posts1,055,548
Members48,425
#1336891 12/08/2019 12:27 PM
I am starting the restoration of my dad's 46 chevy pickup. First I need to remove the engine. I have removed engines before, but from nothing this old. It would be really helpful to have instructions on the removal steps, but I have been unable to find anywhere. Any assistance would be greatly appreciated.
Crusing in the Passing Lane
The front clip(fenders, grille, radiator, etc.) removes as one piece by removing a few bolts, makes the rest of the removal much easier.
What plan do you have in mind for the engine and trans? Running gear?
Ed
There is quite a bit of advice in your first post about this issue.
Another quality post.
Real Trucks Rattle
And you shouldn't need to remove the hood. It makes it easier to re-align everything else on reassembly.
I invest my money in precious metals, mostly rust!
I plan on keeping the truck as original as possible. It currently has the original engine and drivetrain as best as I can tell.
How do you get the U-Joint bolts out of the front of the enclosed driveshaft. I can get the collar back enough to get to the head of the bolts, but cannot get a wrench on the nuts as they are too far inside of the rear of the transmission. Any help would be greatly appreciated as I am stuck at this stage.
