4 members (3B, MickeyP, 1955 1 Series, 1 invisible), 47 guests, and 3 robots.
Topics128,012
Posts1,055,321
Members48,419
#1336794 12/07/2019 4:31 PM
hi, this forum has been a great source for help and info and i thank all the folks who take the time to help greenhorns like me learn and continue the hobby.
i'm working on a 1951 panel that has a 1957 235.
i've had the engine rebuilt using a mild cam, dual zenith 228s, edlebrock intake and fenton headers.
after running great for 500 miles, i noticed a ticking sound that is easy to hear on start up but gets quiter after about 2 mins. im still able to hear it once the engine warms up and it never goes away.
my first thought was a exhaust leak so i brought it back to the muffler shop that built the dual exhaust....3 times. the noise is still there.
now, i'm new to this so i'm still learning. my thought was that it could be a valve/push rod adjustment but i have heard different stories as to wether the valves could be adjusted on this motor as it has hydraulic lifters.
the tick is clearley coming from the top of the engine. if they can be adjusted, what is the process.
thanks for any help that you experts can offer!
doobspanel #1336797 12/07/2019 4:53 PM
A quality mechanic's stethoscope would be a handy tool to find the source of that tick. I hope someone else has a lead for a nice one as I would like to purchase one myself.
doobspanel #1336803 12/07/2019 5:35 PM
Mine is like the walmart mechanics stethoscope.
I think I bought it at my nearby chinese-tool warehouse (Harbor Freight) many years ago.
I do not know how/if a higher priced set would be better? And, WalMart is convenient.
doobspanel #1336840 12/07/2019 11:04 PM
I used to have one of those el cheapo ones. Now it is the neighbor's yard 2 or 3 houses down because that was as far as I could throw it.
I borrowed one from a fiend who got his as a "parting gift" from the Navy. It was much more sensitive. If you barely tough anything, it would sound like someone was yelling at you.
doobspanel #1336882 12/08/2019 4:10 AM
Crusing in the Passing Lane
A dowel, or screwdriver, or wrench extension works well, too, just clean the grease off before sticking end in ear.
Ed
doobspanel #1336883 12/08/2019 4:56 AM
Broom handle will work also.
Brian
1955.2 3100 Truck
doobspanel #1336914 12/08/2019 4:21 PM
ok thanks for all the suggestions on finding the location of the sound. i've taken the valve cover off and i can't SEE anything strange. the noise seems to be coming from the top of the motor. there is no play on any valve/rocker/pushrod regardless if the engine is cold or hot. should there be?
i've got a auto stethoscope on order from amazon and should be here tomorrow but its driving me crazy. the motor is brand new and i'm concerned that this may mean more than a simple adjustment.
any thoughts on that?
also, is there a procedure to adjust hydraulic lifters/valves?
doobspanel #1336930 12/08/2019 5:41 PM
Q
Q Offline
Is it possible to go back and talk to the engine builder? If there is an issuse that would be what i would do.
Quindel54 #1336935 12/08/2019 6:20 PM
Since the truck can be driven, this is exactly what I would do. The machine shop would rather have a look see before anything is done to it.
Carl
