1 members (edgardo), 79 guests, and 3 robots.
Topics128,057
Posts1,055,808
#1335372 11/26/2019 9:44 PM
In my 49 GMC I am using the original speedometer with a 700r4 trans. The speedometer reads approx. 68 when I'm going 60. And the odometer reads 6.5 miles traveled when I have actually gone 5.
The trans has a blue 38 tooth driven gear and a greyish drive gear that I can't count the teeth on.
I read somewhere that each tooth change on the driven gear will change the speedometer reading by 2 mph. More teeth slows the reading and less teeth increases the reading. If this is correct then I would need to install a 42 tooth driven gear. Does anyone know if the grey drive gear can handle the change to 42 or do I need to change the drive gear also? and if so to what and then what driven gear would I use as this would change the overall ratio.
Does anyone know what rpm the speedometer shaft has to turn to have the speedometer read 60mph? This might help me sort this out.
Tom
Riding in the Passing Lane
The housing that the driven gear goes in has the gears number of teeth that can be used with that housing printed on it. About 4or 5 different gears can be used in that housing. I have used plus or minus one also. That may be confusing but clean off the face of the housing & you will see what I mean'
Speedos are calibrated 1000 revs. per mile.
George
1972 Chevy c10 Cheyenne Super
Do a search on "speedometer drive,driven gear calculator" and the TCI Automotive site will come up. Their formula is one that anyone with third grade math can use.
Evan
Public or private school?
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
That is Funny
1949 3100
