7 members (wilbur53, Rusty Rod, D B Cooper, RaNfLaS, Gdads51, KEVINSKI, 1 invisible), 114 guests, and 1 robot.
Topics128,094
Posts1,056,060
Members48,433
#1336587 12/05/2019 10:55 PM
Just got around to installing the temp probe on my 1953 GMC 1/2 ton with a 302-- mechanical (capillary tube) temp gauge. Had planned to use the rear most 1/2" NPT hole in the head. The probe is too long to fit with its adapter, it's about 3/16-1/4" too long-appears the probe hits the top of the block.
Research shows these trucks had their probes mounted on the thermostat housing. My housing has a boss for the probe, needs drilling and tapping--had planned to do that, BUT the capillary tube is TOO SHORT to reach to the front of the engine. Doesn't appear venders sell a longer cap tube temp gauge. Anyone know someone that can build me a gauge, or extend my current gauge's tube? Needs to be 18" long.
phone: 636-219-7705
Crusing in the Passing Lane
Wow, I have seen several that were long enough even for my 503, can you send it back?
Ed
I believe most all the after market ones were longer that the stock ones.
Does it look like this one?
https://www.classicindustries.com/product/1953/chevrolet/truck/parts/cx1722.html
Maybe a real hardware store would have an adapter that may be taller to fit in the head. Just a thought.
Ed
If one uses a tall adapter, I wonder if there is enough circulation around the sensor?
Ed
Bondo Artiste
Bondo Artiste
The thermostat housing was only used for electric temp gauge probes, never the mechanical style probe. Shoot me a email [email protected] and I’ll be happy to send you a pic of my mechanical gauge set up at the back of the block.
~ Phillip
