0 members (),
170
7
Mod | | | Forums66 Topics128,078 Posts1,056,035 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13362 06/03/2003 7:00 PM | Joined: May 2003 Posts: 21 Junior Member | | Junior Member Joined: May 2003 Posts: 21 | I have a 1954 3100 that the previous owner put a mid 60's 235 with a muncie 4 speed. He rigged the motor mounts and really messed things up. I have since removed everything and have purchased the tube style cross member like what Impala Bob's and Chevy Duty sells.
What I need now is the actual motor mounts that will attach the side mount engine to the eye's of the tube cross member.
Thanks | | |
#13363 06/04/2003 2:17 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | flightrn54,
Welcome to the forum.
Are you asking how to mount a mid 1960s 235 to a 1954 truck?
Is yes, here are some things to consider?
1. The 235 was used until 1962 (not quite mid 60s). 2. The 1954-'62 235 truck engine had the same motor mounts (I think). 3. The 1954-'62 235 car engines had motor mounts different from the truck's 235 (I think). 4. There should be no problem getting any 235 installed in a '54 truck - at worst, you might have to use a different bell housing and motor mounts. There should be no reason why a later 235 would necessitate a new/different cross member. 5. It is possible that you have a mid-'60s 6-cylinder (perhaps a 230 or 250).
It would be best to confirm the size/year of your engine before proceeding to "solve" the motor-mount and/or cross-member problem.
Maybe I'm misunderstanding your situation (we will see responses that will correct or clarify my comments).
Tim | | |
#13364 06/04/2003 2:34 AM | Joined: May 2003 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 27 | I've got a 58-62 235 in my 235 with hydrolic lifters telling me that it may be a car engine, I don't know. It looks like the original motor mount is on the front of the engine mounted to a plate behind the timing gears. My problem, and you may have too is the water pump is too long and someone diced up the radiator core support to make it fit. I hope that helps.
1954 Chevy 3100 235 2 Yamaha YSR50's 05 Silverado crew 00 Yamaha TT-R125 Supermoto
#13365 06/04/2003 3:43 AM | Joined: May 2003 Posts: 21 Junior Member | | Junior Member Joined: May 2003 Posts: 21 | I stand corrected I rechecked my numbers and it shows that the motor came out of a 62-78 Chevy, Buick, Pontiac ect. It is a 230 or a 250.
I think the side mounts look similar to that of a V-8, and I am wanting to mate this motor to the tubular cross member.
I have already tried to remove the mounts, and bell housing from my original engine, the bell housing isn't even close.
I just need to find some mounts that will do this.
Thanks Jeff In Texas- 54 3100 | | |
#13366 06/04/2003 4:03 AM | Joined: Jul 2000 Posts: 623 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 623 | I just finished putting a '58 235 from a car in my '53 along with the original 3 speed column shifter. The motor had side mounts when I got it, I removed them, drilled holes in the front mount and it dropped right in. I did have to add a spacer so the larger car flywheel would clear the frame. I also replaced the rubber in the front mount and the one's on the bell housing. If you haven't already you might check out the Tech Tips section there's a couple articles on engine swaps. Good Luck, MONGO | | |
#13367 06/04/2003 7:36 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If your water pump is the only problem then it is done right. You need to obtain or make a shortened water pump. I did the one on my 261 in my '50 truck with a press and got a foamoco pulley out of a junkyard truck that was a bolt on. Here is a pic of the install: [img]http://photo.starblvd.net/~guitarzan/1-1-1.jpg?i=1056349467[/img] All the mounts are in the stock locations, it's a '62 block. It came pre-drilled.
#13368 06/05/2003 2:45 AM | Joined: Apr 2003 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2003 Posts: 140 | OK, your mid-60s 6 takes the new "V-8" style bellhousing, which does NOT usually have mounts the way the old 235 bellhousing did. But, either aluminum or pressed steel bellhousings are available aftermarket, and can be drilled and welded to fit the stock mounts. Disclaimer: haven't done it, have seen it done.
As for the side mounts, more weld and fab, I guess. Dunno for sure.
George '53 3600 | | |
#13369 06/05/2003 10:17 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Not if it's really a 235. If we are talking about the 230/250/292 series, then yes.
#13370 06/06/2003 6:03 PM | Joined: Dec 2002 Posts: 176 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 176 | Originally posted by 4ontheFloor: got a foamoco pulley out of a junkyard truck that was a bolt on. Any transplant rejection problems???
Then you will know the truth, and the truth will set you free.
- Jesus -
#13371 06/06/2003 9:46 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yes, the radiator blew. I'm waiting for a new one. I've put the truck on an anti-reject medication. It's not a good idea to disturb a 50 year old unleaking radiator by putting an electric fan on it.
