| | | Forums66 Topics128,138 Posts1,056,751 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 224 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 224 | My ‘47 AD was painted by the PO. Returning the truck to the original color, Mariner Blue, I’ve found door handles with and without a rubber gasket. Somebody forgot! The front hood “Chevrolet” emblem did not have a gasket. Online I’ve noticed new emblems with and others without a rubber gasket. My question is, originally was there a rubber gasket under this emblem? Seems like it would have been a good idea. Does anyone know the answer?
| | | | | Joined: May 2015 Posts: 11,120 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,120 | Hood emblems didn't have a gasket behind them. Mine didn't. Jim Carter's website indicates it's an optional item for restoration and that GM didn't use them at the factory. Link
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2013 Posts: 224 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 224 | Thanks for the input. Perhaps after the war rubber was still not readily available and at a reasonable price. When I removed mine the repaint was scarred and there was a ton of dirt and pine needles under the emblem. As a work vehicle likely was not an important item. Another learning lesson. 🙂 | | |
