4 members (Hotrod Lincoln, Canadian Dump, Dennys28, Phak1), 130 guests, and 4 robots.
Topics128,165
Posts1,056,987
Members48,458
Sometime over the past 58 years some surgical cuts were performed in the area of the stock radio mounting holes. The metal around the area where the volume and tuning knobs would normal be, was removed. Does anyone know if any kind of custom bezel is manufactured to cover up and dress up this area. Not really interested in any cutting and welding to this area as it has been painted to match the interior. Prefer a thin plate with the cut outs or a custom bezel or even a bezel from another radio that would fit, any help or suggestions would be greatly appreciated, thanks Hugh
Vintage Truck & Tractor
I had to manufacture this radio dash mount after previous owners had done several butcher jobs on the dash. I could not find a chevy radio for a reasonable price so I grafted the radio out of a 72 Ford. A better radio anyway.
Current project; 1961 C20, 235 I6
I have a similar predicament. And I'm thinking of just using a thin piece of wood and add a on/off switch and a volume knob... Bluetooth input only.
[img]https://photos.app.goo.gl/6XRF7P7EQyETT9ST6[/img]
Brad I won one of these bidding on Ebay a while back. Ending up returning it as it did not fit, way too much room between the factory knobs, would not fit a factory radio. Was really looking forward to using it.
That radio trim piece looks pretty nice. What is it called? Can you get it as a repop?
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
Former Workshop Owner
You might try making a card board pattern of what you have in mind and take it to a shop that will laser cut stainless sheet. It's available in both polished and satin finish of many different gauges (thickness). Just a thought. It mostly depends on if you find the right shop that will assist you in converting the dimensions of your pattern into a dxf file. Might not be as pricey as one would think. At least you'd be getting something that you know will work.
Good luck.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
I used a thin piece of aluminum. made the holes for the knobs where they needed to be and made the radio cut out fit accordingly. Then laid it over a pipe and bent a contour to fit the dash
jremig,
Any pics available of ur work, and interest in making one more for a price of course.
Reviving this thread, as I had the same issue figuring out what to do with a mangled mess for a radio hole.... Found this product recently, will see how it goes.
https://ls-fab.com/47-54-chevy-truck-parts/radio-repair-panel-47-53-gmc-chevy-truck/
Not just some but MOST radio panels are butchered on rides we build. We trim the hole to an even rectangle, fit radio to replacement, and then Panel Bond the replacement to the underside of dash. The bond sets up overnight and no side effects like from welding. I like to "French" a modern radio into an old dash as it does not protrude above the dash and has a smooth look to it. A pic of a 49 3100 with a Frenched radio. All repairs should be scheduled before build completed or plan on painting entire dash.
[img]https://i.postimg.cc/0z8S0ggp/dan-s-49-010.jpg[/img]
Evan
