2 members (Hush, Forty9), 90 guests, and 1 robot.
Topics128,050
Posts1,055,643
#1335428 11/27/2019 11:56 AM
Hi, I've been reading other posts about the Motive Brake Bleeder tank system and it sounds like it works pretty well. But I'm curious as to how it attaches to the MC and forms an airtight seal. Does it work if you have a dual MC? After you have bled all four, is the MC full of fluid? Which model works the best ?
1965 Chevy C10 Longbed Fleetside
WarEagle1 #1335430 11/27/2019 12:04 PM
The model I use is called Kathy. Been reliable for the past 46 years. smile
RonR
1970 340 Duster
1964 CJ5
WarEagle1 #1335435 11/27/2019 12:48 PM
AD Addict & Tinkerer
I bought a cheap one on eBay for about $20. It uses air from your compressor to create a vacuum in a canister you attach to your bleeders at each wheel cylinder. It comes with a fill bottle for the MC. I used it on my other truck and it worked good, but not on my ‘52 1/2 ton so I don’t know if the fill bottle will work. It will drain the MC in a hurry so be sure to fill after each wheel.
Phil
Project Journals
Stovebolt Gallery Forum
WarEagle1 #1335443 11/27/2019 2:23 PM
I have a Motive brake bleeder. They have several adapters that connect to various master cylinders. For the dual MC, there is a flat plate adapter that covers both chambers. If you have need for a dual MC adapter, be sure to get the one made out of aluminium. I have found that the fiberglass/plastic ones sometimes flex and leak under pressure and require additional clamping.
SimS
WarEagle1 #1335446 11/27/2019 3:07 PM
A mason jar and a vinyl hose....works every time.
WarEagle1 #1335519 11/27/2019 11:09 PM
Thanks guys
WarEagle1 #1335890 11/30/2019 8:20 PM
Motive brake bleeder works great on the stock (single circuit) master cylinder. I made an adapter out of a spare M/C cap.
1953 Chevrolet 3104 1/2-Ton
More pix
WarEagle1 #1335892 11/30/2019 8:46 PM
Check the Motive website. They make/sell "caps" for most types/brands of master cylinders.
Determine what you need, and then order from Motive or other from other vendors of their products.
WarEagle1 #1336348 12/04/2019 2:38 AM
I use a plastic bottle with a hole in the cap, run a piece of clear tubing that fits the bleeder valve, and presto, a one man brake bleeder system.
Another quality post.
Real Trucks Rattle
