3 members (Hotrod Lincoln, Chip O, Steelonsteel), 125 guests, and 3 robots.
Topics128,196
Posts1,057,391
Members48,471
1950 1/2 ton suburban stock.
My buddy has a 3/4 ton AD truck that has a 1/2 torque tube/open driveshaft. Looks factory.
Anyone ever seen one of those? Can someone use one of those setups to convert a rear end to an open driveshaft while keeping the stock peanut three speed transmission?
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
H Online: Content
That setup was used on long wheelbase trucks because the full torque tube system had problems with the extra length. If you try it on a SWB 1/2 ton, the open driveline section will be too short to work properly- - - -there will be some radical angles involved which will cause vibration and/or premature universal joint failure.
Ahh...ok. thanks!
I wonder why so many do not realize that 3/4 ton trucks had torque tube bells on all their transmissions from 54 back?
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
You need a crossmember to hang the intermediate bearing. But it can be done.
Check illustration
Check this POST
Check attached pics
2nd pic shows 4 speed trans.
xfiles
H Online: Content
It's technically possible, but I believe you would need to shorten the torque tube section by a foot or more to be able to use a long enough open driveline to avoid problems with angularity. That would require some pretty creative machining, especially on the internal driveshaft- - - - - -cutting new splines, etc.
I can’t see how the torque tube length would be an issue on a suburban, my 1940 1.5 ton has a very long torque tube.
It would be easier to flip the 1/2 ton torque tube leaf springs and use a open Hotchkiss axle.
Then change out the torque tube 3 speed tranny for a open 3 speed tranny and have a machine shop make-up a two u-joint propeller shaft. Or find a 1955 1st series 1/2 ton truck and swap the drive train & rear leaf springs.
Jim Carter tech tip Alignment Solution Rear End (loads slow)
Also check attached pic
xfiles
