Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (homer52), 118 guests, and 6 robots.
Topics128,281
Posts1,058,469
Members48,490
#1335483 11/27/2019 8:08 PM
A little help please. I am trying to finish my restoration and I'm down to the brakes before I can go for a test drive. For the last several days I have been trying to get the brakes to work. I have bled the four wheel cylinders at least 6 times all around. I don't believe there is any air in the line but I still have a soft pedal. If I pump the pedal 6-10 times the pedal firms up a bit but 10 minutes later........no pedal pressure and I have to pump the pedal again. Should I recheck the brake shoe clearance and recheck the pedal to floorboard clearance on the backside? Any thoughts from anyone on what is my problem?
Jhyp #1335487 11/27/2019 8:30 PM
Crusing in the Passing Lane
Have you adjusted the shoes out enough so they are almost touching? If not, several pumps will be required just to get them out to the drum
Ed
Jhyp #1335507 11/27/2019 10:13 PM
Did you Bleed the Master Cylinder?
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Jhyp #1335510 11/27/2019 10:19 PM
I don"t care I"ll bring it up. How do you Bleed the Master cylinder? I owned about 30 cars from all over the world. Never have I needed to Bleed the Master Cylinder. So How is it done.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Jhyp #1335514 11/27/2019 10:55 PM
AD Addict & Tinkerer
My new MC came with a plastic plug that I screwed into the outlet port. I supported the MC in a vice. Filled the MC with fluid and slowly pumped the rod while looking inside the reservoir looking for the air bubbles to stop. Takes 10 or more pumps to eliminate the air.
I’ve also seen a kit that contains a nipple and a tube (or two for dual MC) that screws into the outlet, then you place the tube into the reservoir filled with fluid and pump until there is no more air bubbles in the tube.
It’s important to keep the MC full while you bleeding it.
Phil
Project Journals
Stovebolt Gallery Forum
Jhyp #1335526 11/27/2019 11:59 PM
I'm sure there are lots of youtube video on how most MC's are bled, while on a shop bench. That's how I've done mine before.
Craig
Jhyp #1335538 11/28/2019 12:35 AM
Assuming that you have Huck brakes, I will ask a stupid question. Take no offense please.
Are you adjusting both stars on each wheel?
One thing that I have found beneficial for bleeding Huck brakes after major changes (new shoes, turned or new drums), is to adjust one star until you can barely turn the wheel, then back it off until you can just turn the wheel with some drag. Do this with all eight stars. This will take all of the mechanical slop out of the shoes, allowing them to solidly contact the drums without excessive pedal travel..
Now double check the master cylinder push rod adjustment as per The Manual.
After this, bleed the brakes.
Once you have a high, firm pedal, adjust the brakes as per The Manual. There will be no brake drag after this adjustment.
If none of this works, you need a new master cylinder even if the one you currently have is new, All too often, we find bad new master cylinders for every vehicle made these days.
Carl
Jhyp #1335599 11/28/2019 1:50 PM
Thanks everyone for your help.
