Hey guys, searched for about an hour with no luck.
I have a set of '53 doors (with vent windows) that I'd like to use the earlier, full glass in. (vent delete).
I thought it would be a straightforward swap, but it looks like the crank mechanism may be in the way.
Can anyone give me some info on this swap? I swear I read it could be done (when I wan't at that point), but now That I need the info, I can't find it.
In this case, I removed a good portion of the skin, to get out a large, poorly repaired dent (about 1/2" of bondo in 1 spot). I figured I can do the swap, with great access, so I can understand how to do it on the other door.
Thanks, I appreciate the help.
Rick
[img]
https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/download/Number/13105/filename/IMG_0168.jpg[/img]
