4 members (frogfarmer, dt235sd, Frank50, 1 invisible), 267 guests, and 6 robots.
Topics128,077
Posts1,056,012
Members48,433
#1334454 11/20/2019 11:55 AM
Well, the whole motor is odd - a 1953 block, with a 54 235 head. The head was removed awhile back, and I was getting everything "rounded up" to work on it. I noticed one of the head bolts is :"shaved" length-wise. I have no idea which hole it came out of, nor do I know the reason it has been shaved down. Anyone have a clue???
AD Addict & Tinkerer
Can you post a picture?
Phil
Project Journals
Stovebolt Gallery Forum
I've seen this before...it's a backyard method of getting oil to the rockers. See the following link to answer why it was used and where it came from:
http://chev235guy.blogspot.com/2012/09/drilled-head-bolt-drilled-head-bolt-is.html
You Tube
That links shows/explains a Chevrolet-provided technique/bolt for " . . . using 1958 or earlier rockers on a 1959-62 engine".
Does your bolt have a hole in the bottom (see attached images)?
(images take from Pre '68 Dave's excellent blog site - at the link in an earlier post in this thread)
A shade tree method of accomplishing the same rocker arm oiling as the drilled head bolt is to grind a flat spot on the threads of the center head bolt on the passenger's side, or cut a slot in the threads with a cutoff wheel in a Dremel tool or a small angle grinder.
knuckle head
knuckle head
Why cut a slot in the threads? The oil from the block doesn't come past the treads from what I have seen....
The drilled bolt provided a path for oil to get past the threads. A slot would accomplish the same thing.
knuckle head
knuckle head
The 55 and up 235-261's I have seen, quite a few, have an oil passage next to the center bolt threads...then it crosses over via a cut out in the head gasket and then up past the bolt shank, not the threads...Look at a bare block and trace the oil pathway...
