3 members (jasrking, TooMany2count, FishinToms53), 125 guests, and 0 robots.
Topics128,126
Posts1,056,354
Members48,441
Fox
Offline
Have you ever heard of these? If you haven’t, do some google research into JIS and you might discover why you’ve been stripping Phillips headed screws and such so much. I think I’m going to get a set of vessels. I have done the dreaded stripped bolt head on rotors before. What a PITA.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
AD Addict & Tinkerer
Interesting Fox. I just googled it and JIS stands for ”Japanese Industry Standard”. Hopefully we won’t find them on our “Stovebolts”.
I do know what you mean about stripping screw heads. Now I know what to look for.
https://chapmanmfg.com/blogs/news/phillips-bits-vs-jis-bits-whats-the-difference
Thanks Fox!
Phil
Project Journals
Stovebolt Gallery Forum
Moderator
Moderator
2 Offline
Good info! I did not know that.
Thanks For Sharing
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Big Bolt Forum Moderator
interesting.....
Mike
Former Workshop Owner
I have noticed screws with that marking in the past. Now I know what it stands for. I will be buying a set of JIS screwdrivers in the near future. thumbs_up
Thanks for the info.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
So does a JIS screwdriver work in Phillips screws (not cam out like Phillips drivers tend to do)?
Phillips screws and drivers were designed so that it limited the torque applied to keep ham handed assembly workers from stripping threads on the screws.
From the info presented, JIS screws and drivers eliminate the cam-out issue, but it's not clear that a JIS driver will work any better than a Phillips driver in a Phillips screw.
Robertson (square drive), Allen (hex recess), and torx (modified hex) serve the same function (eliminate cam-out) but of course you can't use those on Phillips screws.
I’ve looked on several sites and they all said the JIS drivers work on Phillips heads. None said they worked any better than a Phillips bit. The reason I found it really interesting is, in the past I’ve ran across many screws heads that I thought to be Phillips screws and a brand new driver didn’t fit tight, so they would strip before getting them tight. I surmised they were cheep Chinese made fasteners but I may have been wrong. I’ll buy some JIS bits and maybe that will solve that problem.
Phil
Project Journals
Fox
Offline
My friend told me about this. He said he will never by a Phillips again. Vessels work both ways, but the Phillips does not. It can’t hurt to try.
I know what’s on my Christmas list now!
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
H Online: Content
There are several "cross point" screw head designs, and none of them interchange exactly.
Phillips
JIS
Posidriv
Reed & Prince
The R&P is especially troublesome, as makers of cheap screwdriver sets included them instead of Phillips. Phillips was a patened design a few years ago, and manufacturers had to pay a royalty to produce their drivers. If a cross point screwdriver has a sharp point and straight-taper flutes, it's a Reed & Prince, and it will destroy a Phillips screw instantly. R&P was used in assembling some types of furniture- - - -never in automotive applications.
Moderated
Moderated
Glad to hear our website was helpful! Thanks for posting, there's a lot of confusion (understandably) about JIS vs. Phillips.
Side note, we have a company '59 Apache that we restored, you can see the pictures here: https://www.facebook.com/pg/ChapmanMFG/photos/?tab=album&album_id=367021406703893
Joel
VP @ Chapman MFG
Thanks Fox!
Joel
VP @ Chapman MFG
Glad to see another '59 Apache out there. The finished product looks GREAT! All that participated in the different stages of the build have allot to be proud of.
Moderated
Moderated
Thanks, it was a labor intensive but fun project! We love the truck, the color combo turns a lot of heads (especially kids) at car shows.
Joel
VP @ Chapman MFG
24601
Glad to see there is still some real industry/tool and die manufacturing in Connecticut thumbs_up
And welcome to Stovebolt.com!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
I have a set of Vessel JIS screw drivers and use them on Japanese motorcycle carburator screws, and for that alone they are worth it! Three sizes cover most any need for these screws.
1959 Apache 31
Anyone ever use a square bit in a hand drill to drive Phillips deck screws? You would if you ended up at a job site 100 miles from the closest town which is 200 miles from where you can by Phillips bits.
Guess what? They work surprisingly well.
@52Carl;
Some deck screws are "hybrid". They can be driven with both a square drive and/or a Phillips bit. I'm using the deck screws with a Torx drive. Pretty slick.
SimS
Originally Posted by SimS
@52Carl;
SimS
You got that right about the Torx drive deck screws. The ones I buy come with a nice bit.
Moderated by  MNSmith
