1 members (Materman),
115
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2019 Posts: 13 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 13 | Need to rebuild my door hinges. 57 Gmc 9300. One search said the correct kit was the Dorman 703-264. Two pins, two sets of bushing, standard and oversized if needed. But the Dorman site said this kit would not fit my truck. Is this the kit for the job ?
57 GMC 9300, 235, MS318, S45
| | | | | Joined: Mar 2010 Posts: 118 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 118 | Can't remember, but what size truck is the 9300? I know it's the canadian model. Other than that, I would think all the door hinge pins would be the same for all sizes of these trucks regardless of 1/2 vs 2 ton truck. I bet Dorman is saying it doesn't fit because it doesn't recognize the Canadian model designation. Look up the same kit for the US model number, I bet it will work. | | | | | Joined: Nov 2019 Posts: 13 'Bolter | | 'Bolter Joined: Nov 2019 Posts: 13 | The 9300 Canadian model is a 3104. I talked to the guys at Scott’s Super Trucks. Their have them. Part number L60.
