2 members (RoadsScholar, 1 invisible),
154
Mod | | | Forums66 Topics128,087 Posts1,055,976 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | I plan to install a 1964 327 V8 into my 1957 Chevy NAPCO truck. The engine appears to be a1964 truck engine based on the numbers. I’m trying to find out if this engine originally had an alternator or a generator. Any ideas of where to look are appreciated. Thanks, Larry | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | | | | | | Joined: Feb 2004 Posts: 29,782 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,782 | I'm pretty sure 63 was the first year for alternators, the ones with a 4-connector external regulator. Those things are a royal pain in the butt to work with. Unless you're building something that's supposed to look factory original, a 10-SI internal regulated alternator from the middle 1970's or newer would be a much better choice, reliability-wise. Jerry
| | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | Thank you. I’m trying to stay period correct, but it will be a driver and get used as originally intended so I’m okay with upgrades. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | I hope that you are planning staying out of the gas pedal. 327s are short stroke engines and rev up real fast. You have 4 u-joints and a transfer case designed to handle a low RPM 125 HP inline six 235. I am not trying to dissuade you from doing your swap, I just know a guy with a '57 NAPCO who went with a 300 hp 350 crate motor and could not keep the bearings in the transfer case or was blowing out U-joints. Granted, he could not keep his foot out of the gas.
| | | | | Joined: May 2007 Posts: 226 'Bolter | | 'Bolter Joined: May 2007 Posts: 226 | Hi Carl. Thank you for the warning. I do understand the risks involved with running the 327. There was a guy many years ago in our area who put a 389 in his GMC version of a Cameo that was also a NAPCO conversion. He was known for destroying the spider gears in his rear differentials by doing burnouts. I had a 1958 GMC factory NAPCO Carryall that had a 389 installed after the 336 wore out. I never had any problems other than keeping the fuel tank full. This is a truck version of the 327, 2 bolt mains, focus on low rpm torque etc. I’m 71 years old so I probably won’t get too crazy with the skinny pedal. Again, I do appreciate you advice. Thanks, Larry | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Can't wait to see some pictures, Larry, better yet, I'd like to hear it run. I love the sound of those short stroke bumblebee engines.
| | | | | Joined: Feb 2004 Posts: 29,782 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,782 | You'd love the short stroke screamer I've got on the drawing board- - - - -a 305 block with a destroked 283 crankshaft- - - -a 2 7/8" stroke crankshaft in a 305 block gives a displacement of 250 cubic inches- - - - -sort of like a bumblebee on steroids! Jerry
| | | | | Joined: Mar 2007 Posts: 3,386 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,386 | HRL, I would love to see that built. I have always thought about a built 305 or 307. I had a 305 with a Crane version of the Duntov 30/30 cam, it sounded nasty.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Feb 2004 Posts: 29,782 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,782 | I'm tinkering with the idea of equipping that one with a roller cam and a rev kit- - - - - -with a power band somewhere in the 8K+ RPM range! Jerry
