3 members (Gray_Ghost, tesa, Johnny N), 88 guests, and 1 robot.
Topics128,076
Posts1,055,924
Members48,430
#1334312 11/19/2019 5:13 AM
Where is the best place to buy clutch head screwdrivers? The ones I purchased were of poor quality and sizes did not match up. I’m using screwdrivers on my 1950 4400.
Brad1950 4400
From whom did you buy your poor quality clutch head bits?
That information might help/warn a future bolter/buyer?
Try these,had great luck with them pretty strong.
https://www.amazon.com/Vermont-Amer...rewdriver&qid=1574166471&sr=8-19
!956 Gmc Napco 4x4 Factory line built .
Try your local NAPA store.🛠
The Snap-On truck rolls in to my place every Thursday, so......
The Vermont-Americans are good.
I got screwdrivers off amazon at this moment I can not find the name of the brand. Thanks for everyone’s advice.
Brad1950 4400
AD Addict & Tinkerer
I got mine from Classic Parts. In hindsight would have gotten the ones that attach to the ratchet. Although I haven’t had any clutch drive screws I haven’t been able to remove, I suspect once I get to the bodywork, the Clutch Drive Socket Set may have more power to remove the screws. I will probably be buying a set of the sockets.
Phil
Project Journals
Stovebolt Gallery Forum
The socket type rock!
My only issue with them is that they're a touch too long. A little shorter would help with leverage. I may whack mine down a bit.
My set came with long and short ones.
What I would like to find is a 1/4" drive clutch head sockets. I don't need 3/8" drive "horsepower" for these fasteners.
With 1/4" drive, I could use my 1/4" ratchet plugged into the handle of my 1/4" drive nut driver.
This would provide a great amount of control while removing these fasteners.
Amazon has these that go into a 1/4” screw gun.
Phil
Project Journals
I bought the "long" clutch head socket set and it performs poorly, Since then I have purchased used Proto Tools clutch head sockets off Ebay and although I had to purchase from more than one seller to get what I needed, the results were worth it. The Proto clutch head sockets fit the bolts like a glove, very obvious improvement.
Ron - - Dusty53
1954 Chevy 3604
I may get a set of those. Would work nicely in a 1/4" hex drive impact driver I have. Impact would also help knock the rust loose.
Thanks for all your help. You guys are the best!! Below is a picture from amazon.
Brad1950 4400
Picked up a set of these recently:
https://www.amazon.com/gp/product/B01LX661P8/
I prefer the sockets simply for the option to use in either a ratchet or cordless impact. Haven't yet tried these but will update the thread with anything material.
Ryan
'54 3100
Moderated by  MNSmith
