4 members (Gdads51, Gib70, tclederman, Gray_Ghost), 158 guests, and 3 robots.
Topics128,078
Posts1,056,021
Members48,433
#1334069 11/17/2019 1:00 PM
Jolly Roger
Jolly Roger
i have a 1951 chevy 3100 with a original correct horn i found at a parts yard. it works perfectly fine when i manually short the contact to ground, but when i depress the horn button it only activates (the horn just clicks on/off not making noise). is a bad ground my issue? all the wires up to the horn button are fine but the horn button seems to be my issue. also i dont have a relay in the circuit, but since it works i dont think thats my issue.maybe take the steering wheel off and clean all the contacts? im out of ideas if someone would so kindly provide some insight.
edit: the horn has a relay built into it, so thats definitely not my issue
Owner of the most temperamental 1951 3100 in existence
I don't believe the original horn had a relay built in. It sounds to me like you have high resistance in the ground (horn button) circuit. You could add a relay to solve the issue, or track down the high resistance.
Jolly Roger
Jolly Roger
im calling high resistance on the ground end, because everything is new, therefore it could have a factory coating that negates conductivity. ill take the wheel off and wire brush all the contact points. its a start at best!
Jolly Roger
Jolly Roger
quick update: my truck blew up, so i no longer need assistance. thank everyone for their time
You pulling our leg? ohwell
Haunting the SBP since 2001
