1 members (Cletus1950), 77 guests, and 2 robots.
Topics128,151
Posts1,057,000
Members48,460
#1334287 11/19/2019 12:32 AM
I picked up seatbelts from LMC truck today and am going to install on my 49 that I just bought. Anyone have recommendations on how they install . Just bolt through the cab?
Insomniac
Insomniac
Gord 🇨🇦
1954 1/2 ton 235 4 speed
No sir but I will. Thank you
Are you doing 2 or 3 point seatbelts?
1950 Chevy 3100
2 point.
I have 2 point on my '50 3100. Bolted the straps to the seat support fram, down in back. Very simple.
Craig
I put a 2" piece of angle iron across the bottom of the cab for my seatbelt install (39 chevy pickup).
Another quality post.
Real Trucks Rattle
Do you have any pics showing how you did this? Thank you
1937 Chevy pickup
1952 MGTD
I put 3 2-point sets in my 1950 3100
Do not forget steel plates underneath. Otherwise God forbid you get into an accident the seatbelts could just rip though the floor .
I'll try and find a picture.
1950 Chevy 3100
This is where passenger seatbelt meets middle seatbelt steel support under cab.
1950 Chevy 3100
AD Addict & Tinkerer
I did basically the same with mine. For the outer belts, I followed Deve’s installation but bolted the L bracket thru the floor instead of welding it. That is shown in the forth picture without the retractor (I installed 3 point belts, but the attachment points are the same). I used a 1-1/2” x 4” x 1/4” plate, which slid nicely under the cab attachment bracket to bolt the L bracket into.
The issue I ran into was routing the center belts thru the seat cushion frame. The belts would rub on the sharp edge of the seat frame. I remedied the issue by cutting slots for the belts to run thru. Instead of cutting rectangle slots, I cut slits that looked like a wide H with a cutoff wheel on a grinder and a Dremel with a cutoff wheel for the side cuts, and folded them over so they didn’t leave a sharp edge.
Phil
Project Journals
Stovebolt Gallery Forum
Phak1,
I believe when I did mine there were no sharp edges. I just put thick sticky padding where the seatbelt touched the frame through to cushion.
But they look the same.
Better than nothing at all.
1950 Chevy 3100
