3 members (Wheelie, tclederman, Woodcmiami), 113 guests, and 1 robot.
Topics128,113
Posts1,056,279
Members48,439
#133421 12/12/2005 3:49 AM
Does anyone know a manufacture of a dropped axle for a 37,I have found them for 47 and up but nothing for the 46 on back. I was considering a IFS but if I could find a dropped axle that would work. Jeff
#133422 12/12/2005 4:38 AM
Junior Member
Junior Member
Im in the same boat as you man! I got a 38. I don't think Im ready for a IFS swap. If you want to just drop your axle, you can use lift/lowering blocks.
#133424 12/12/2005 5:33 AM
Contact Mor-Drop Axle in Oakland CA. They have been dropping axles since the '50's
1949 chev 3100 3 window. 350hp/327/m21 4 spd, 12 bolt rear, power brakes, 3" dropped axle from Sid's. Disc brakes next.
#133425 12/12/2005 5:36 PM
Junior Member
Junior Member
jeff, Speed had mentioned something about converting to tapered wheel bearings on our axles. I never did get to the bottom of it. Perhaps before you get your axle dropped, you may want to consider changing to one with tapered bearings.
Like I said, Unfortunitly, I don't have any concrete info on this,
#133426 12/16/2005 5:06 PM
I had these guys drop my axle for my 48. They do a great job.
-Rich
http://www.roadsters.com/axles/
