6 members (Bill Hanlon, Donf, MickeyP, Hotrod Lincoln, mick53, FAST55), 109 guests, and 1 robot.
Topics128,049
Posts1,055,701
#1334088 11/17/2019 4:38 PM
Anybody got just the threaded collar for the rear of the U-joint ball that they are willing to sell? The one I got off eBay got a little dinged up in shipping.
[img]https://photos.smugmug.com/Cars-and...ed/i-vHqfGWg/0/fefc0f6c/M/IMG_4808-M.jpg[/img]
1953 Chevrolet 3104 1/2-Ton
More pix
Place a Want Ad in the Swap Meet (not in this forum).
That threaded torque tube retainer cap is also suppose to have two O ring washers. illustration and HERE
Group # 5.576 Part # 595013 ..
I don't think there is part number for just the torque tube retainer cap, not sure?
Call http://nwtparts.com/ ask for John
You probably need a Seal Kit also.
Thanks for the lead, I will check with nwtparts.
More pix
"That threaded torque tube retainer cap is also suppose to have two O ring washers."
two metal washers (one on each side of the 0-ring)
That O-ring was a squared-edges rubber seal in the kits that I have received from reproduction parts vendors.
No leaks after many years.
Clean the torque-tube until shiny where that seat sets/seats on the torque-tube
Put a little grease on the mating surface/area.
If that area is not pitted, you might not get a leak there.
Chevs of the 40s
Classic Parts (Chevy Duty)
Jim Carter Truck Parts
I have an extra nut and may have the metal washer that goes with it if you don’t get anything from NWT.
44 Canadian chevy 1/2 ton
