2 members (JeffA, Mike B),
167
Mod | | | Forums66 Topics128,162 Posts1,056,938 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Hard to determine.
A shiny "pig-in-poke"!
Glossy paint job, but, "The outside is cleaned and painted but i haven't done anything with the inside it ran when i took it apart to clean it." | | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | That's what's known as a "rattle can rebuild". Basically, you're buying a paint job. The price is at least twice what I'd offer, possibly three times. Unless you can hear an engine run it's a "rebuildable core" and you should offer an appropriate price.
Pros: 61 is one of the most recent manufacture 235's- - - -they stopped installing them in either 61 or 62, depending on who you ask. It will have the 848 casting number cylinder head, which has a higher compression ratio than 56 and earlier engines. If it's out of a car, it's probably got hydraulic valve lifters. That can be good or bad, depending if the lifters work properly.
Cons: The low-mount water pump won't work well with the 1940 radiator. The fan sits too low and might hit the lower radiator hose. You'll probably need to install a pump relocation plate to be able to use the 216 style water pump. Unless the owner is willing to provide the intake and exhaust manifolds, carburetor, generator, distributor and starter in the purchase price, you'll end up spending big bucks rounding up enough accessories to complete the project. That one's a $200.00 maximum engine in my neighborhood. Jerry
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | We used to call them spray can rebuilds, beware of the engine that has had no work and looks shiny painted, should be considered to blow nice blue smoke. Unchecked engines should get no more than core value.
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Mar 2010 Posts: 10,299 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,299 | It sure is purty. Too bad the paint will be destroyed by the hot tank that your engine rebuilder will need to do before he rebuilds the engine for you.
| | | | | Joined: Aug 2017 Posts: 671 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 671 | I bought one similar to this (Complete) for $250. Seller said it was .010 over ran good when pulled ect...I opened it up it was .080 over with very bad cylinder walls...unless you run it or open it it's like a Cracker Jack prize (Unknown). Luckily the carburetor, started & generator were good. Also the Intake/exhaust. The head was "848" and not cracked. Those were worth the $ but I was out a block.
1950 Chevy 3100
| | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | That 80 over block would be a good candidate for six sleeves and a set of STD. bore pistons. I used to do that with "junk" racing blocks my competitors were throwing away. Eventually they figured out they were getting beat with their own discards! My students needed blocks to practice machining on, and the guys who sponsored my race engine building program appreciated the chance to get a race-prepared block at a bargain price! Jerry
| | | | | Joined: Mar 2010 Posts: 10,299 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,299 | Yep, and all you need is a $80,000.00 worth of machine equipment and tools (used prices), and a HRL to run the equipment, but I think they quit making those a long time ago.  Carl
| | | | | Joined: Apr 2010 Posts: 245 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 245 | "had the exhaust manifold powder coated"...does he have the rest of the missing engine parts not in the photo? | | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | Yep, and all you need is a $80,000.00 worth of machine equipment and tools (used prices), and a HRL to run the equipment, but I think they quit making those a long time ago.  Carl Hmmmm- - - - -I guess my $750.00 used Van Norman boring bar and a 3 lb. BFH to drive the sleeves in with won't make the cut. Please don't tell all those blocks I salvaged with that setup that they won't work- - - - - -I'd hate to have to give all those winnings back! Jerry
| | | | | Joined: Jan 2000 Posts: 591 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 591 | If you are looking for a another engine, why not a 261 instead. Pretty much everything is interchangeable with the 235. I had one (bought the rebuilt block from Tom Langdon) and used my 235 stuff including the 848 head. Added dual carbs, exhaust and HEI. It was a great running engine with good power. However, I doubt it will be as cheap as a 235 (both are great engines). don | | | | | Joined: Oct 2019 Posts: 238 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 238 | Mostly because I don’t know where to find a 261, and this 235 is about 15 miles from Me. | | |
