| | | Forums66 Topics128,162 Posts1,057,068 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 94 | hello , i had a friend of mine look at my straight axle loose kingpin on my 1939 chevy truck after new bushings were replaced . he noticed the kingpin lock bolt shaft was to long , sticking out the other side hitting the back side of the wheel stop . this caused the kingpin lock bolt not to tighten up correctly , leaving the kingpin loose . he made a small counter sink in the back side of the wheel stop enough to clear the extended locking pin bolt . this tightened the kingpin right up . amazing what a second set of eyes can see and made a simple fix . hope this helps anyone . 1pete1 | | |
