3 members (KEVINSKI, Bill Hanlon, JW51), 229 guests, and 1 robot.
Topics128,101
Posts1,056,180
Members48,436
#1333920 11/15/2019 8:47 PM
I
I Offline
Just pulled the head off my '49 3600 216 with 46K miles. It seem to run pretty well but huge cloud of smoke until it warmed up. Then just a little smoke. Also no smoke on compression going down hill so I was guessing it need valve seals and maybe a valve job.
The head has cleaned up pretty well and is straight. But the valves look bad. Also some of them are flat and some cupped. Not intake one way and exhaust the other. All were very difficult to clean up and some have pits and they had lots of carbon on the mating surface. So I'm guessing someone put a handful of other brand valves at some point. Pistons had carbon but cylinder walls look great and almost no ridge.
Anyway it looks like I'll need to buy new valves. So my question is where should I buy them? Can I just seat them in with dual grit compound?
Thanks for the help. Larry
Last edited by Peggy M; 07/23/2024 4:57 PM. Reason: added full truck year to help with searches ;)
1949 3600 216 4 speed (completely original)
Valves are only one third of the equation. You also need to have properly-fitting valve guides, and the correct position and width of the valve seats. You'll also need to get the head magnafluxed to check for cracks. Doing a shade tree job after buying a whole set of valves would be a really bad decision. Bite the bullet and let a good machine shop do their thing.
I
I Offline
Thanks Jerry, I'll check out having the head done by a machine shop. Still seems odd to me that the valves don't match. Do you know are these value usually flat or cupped? The valve seals were still in place but they were pretty hard. However I removed them all without breaking any. They are just little rubber rings similar to o-rings. Do the new seals the same or more like a newer engine at the bottom of the spring? Larry
Those rubber O rings are supposed to prevent oil running down the valve stems and puddling on top of the guides. If you choose to use some type of umbrella-style seal, DO NOT double up and use the O rings as well. It's possible to get too much of a seal and wear the guides out from lack of lubrication.
' Offline
Larry ,
I'd be very leery of the quality of aftermarket valves .
IMO most of the stuff being sold is made in china junk .
My choice would be GM NOS parts for your valve job .
These parts can still be purchased NOS .
You can go to ebay & type in the part # in the search box .
Intake Valves - GM part # 3688760
I see GM NOS inlet valves on ebay .
Dan's GM Obsolete
Chinook , Montana
phone : 406 - 357 - 2615
Dan's has ( 15 ) GM NOS intake valves in stock .
PIC
https://i.postimg.cc/HsF27qH1/Intake-Valves-GM-3688065.jpg
There are Exhaust Valves available on ebay .
Exhaust Valves - GM part # 3835318
PIC
https://i.postimg.cc/MHMB6GnM/3835318-exhaust-valves.jpg
Dan's GM Obsolete has ( 8 ) exhaust valves in stock
Intake Valve Guides
GM part # 3688760
There are some on ebay
PIC
https://i.postimg.cc/4y9KCF0p/Chev-216-Inlet-Valve-Guides-3688760.jpg
Exhaust Valve Guides
GM part # 3688761
PIC
https://i.postimg.cc/BnspJd0S/Exhaust-Valve-Guides-GM-3688761.jpg
Dan's has ( 18 ) exhaust valve guides in stock
Valve guide Seals
GM # 3835333
There are some nos seals on ebay
PIC
https://i.postimg.cc/HLnQxmPg/Valve-Seals-GM-NOS-3835333.jpg
You may want to consider new nos valve springs
They show up on ebay quite often .
PIC
https://i.postimg.cc/wTkJQMCz/Chevy-216-6-Cylinder-Valve-Springs-GM-NOS.jpg
https://i.postimg.cc/Ls74v0gM/839304-216-valve-springs.jpg
You should check on the condition of the valve spring caps
GM part # 3835392
PIC
https://i.postimg.cc/6qX2dxzT/Valve-Spring-Caps-GM-NOS.jpg
Valve Stem Locks
IMO they should be replaced .
PIC
https://i.postimg.cc/FFV12qDg/Valve-Stem-Key-Locks-GM-NOS.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Stovebolt six exhaust valves are identical to the ones used in a lot of small block V8's. There's no point in paying outrageous prices to some resto-ripoff place for part number matching exhaust valves when stainless steel exhausts are a dime a dozen from lots of online suppliers. They're better quality and more durable than OEM valves, and they'll probably last as long as you own the truck. The intake valves are sort of oddball- - - -I don't know of a suitable work-around on them.
I
I Offline
Hey thanks again. I already found that NAPA has the intake for $21 while the exhaust are $7 each.
