| | | Forums66 Topics128,040 Posts1,055,478 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | does any one have a mustang 2 frount end under your truck with a v8 in it looking to do this to my truck but would like to know the finish ride higth on frount.also what kind of rears are you guys using with out cutting them down my truck is a 42
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I saw several done like that in car shows this year. That IFS literally slams the front of your truck close to the ground. If you like that look, the ride is said to be very supple and car-like. But if you like your truck to look more trucky than that, then perhaps another option will work better, like maybe a more modern 2WD truck's IFS instead of a Mustang II IFS.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | It dropped my 39 about 8 inches. I used a hiedts (spelling?) crossmember. http://hotrodders.com/gallery/data/500/medium/IMGP0116.JPG As far aa a rear I used a 9" ford out of a 72 Cougar, It was about a 1/2" wider than the original. | | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | I put a M II frontend under my '46 Panel, with stock spindles, no drop. And it didn't lower it that much, it looks like a normal truck right now. I can't tell you the exact distance right at the moment because the fronts on jack stands while I'm putting the front clip on and wiring in but without the fenders it did not seem allot lower to me. The bottom of the crossmember is still 9-11" off the ground with 15" rims and 235 tires. I've been looking at it without the fenders on and am still thiking about 2" drop spindles for it in the spring. Give me a few days and e-mail me I'll let you know more after I get it off the jack stands. As a matter of fact e-mail me anyway cause I've got some pics of it on another site and I'll let you know where you can see it without the front clip.
David Just a firefighter, Cleverly disguised as a responsible adult '46 1/2 T Panel
| | | | | Joined: Oct 2005 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 32 | i hade a valarie front clip on the front of mine and it loked good. had no motor no trans looke about like stock height if you put a motor in it would probably settel down a few inches. | | |
