2 members (Hush, Forty9), 90 guests, and 1 robot.
Topics128,050
Posts1,055,643
#1333758 11/14/2019 3:29 PM
1 Offline
I have a 1939 chevy truck 1.5 ton , it has a sbc 350 with a manual transmission . any ideas for a clutch linkage to fit this type of modification ? thank you 1pete1
1pete1 #1333808 11/14/2019 9:56 PM
H Online: Content
Check out the hydraulic throwout bearings used on circle track cars. It's a lot simpler to mount a master cylinder clutch pedal and run a piece of flex tubing than it is to Rube Goldberg some sort of mechanical linkage and hope you get the geometry right.
1pete1 #1333841 11/15/2019 3:26 AM
Yea..... use all the stock parts. They all fit. I have a LS in mine with a old style open bottom v8 truck bellhousing with the stock 1949 gmc fork and a shiney new link bar from jim carter. It all hooks up like stock with no problems........ as long as you located the motor in the correct spot.
1pete1 #1333979 11/16/2019 1:57 PM
Here is my hydraulic throwout bearing. I made the cover. Simple one line in. The second line is a bleeder valve.
1pete1 #1334142 11/18/2019 12:37 AM
I have a hydro on my t56 in the racecar. It works fine but I actually like the feel of the mechanical setup better. If you just have a sbc in it and the actual bellhousing flange is in the stock location then the stock linkage should just bolt on like stock.
