6 members (51sub, JW51, 55shaker, Stovebolt48, Gray_Ghost, 1 invisible), 71 guests, and 0 robots.
Topics128,042
Posts1,055,595
#1333577 11/13/2019 4:00 AM
Good Evening Stove Bolters,
The gauges in my 46 appear to be the same gauges they had in the 36 - 39. Does anyone know if they installed the older style gauges in the 46 2 tons? I ask because it doesn't look like they were ever changed out but who would know the whole history of these machines.
Thank You all in advance
Kregus
Lakewood, CO
1946 2 Ton (I think)
Kregus #1333603 11/13/2019 2:17 PM
It looks like you have a truck from the 30's.
Here is a photo of the dash in the 1940-1946 and the front end. These are of a 1946 truck.
Harold
Harold
Kregus #1333604 11/13/2019 3:01 PM
My guess is that you have the smaller dash (with accompanying gauges) from 36-39, grafted or bolted on to a 41-46 truck. The windshield has a dividing bar, not correct for the earlier trucks which had a single piece of flat glass. The steering wheel is 41-46 also. It actually looks pretty good and I was just go with it. The vendors have inexpensive decals for the earlier gauges so you can just fix 'em up.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
Kregus #1333605 11/13/2019 3:04 PM
Crusing in the Passing Lane
Look like the gauges on my '37 GMC. Can you post a picture of your truck?
Ed
Kregus #1333619 11/13/2019 4:24 PM
3B Offline
Hy Kregus and guys, the first year of that cab design was 1939 and that was the only year they had the dash that Kregus sent us a picture of. If Kregus could send us his trucks serial number we would know if he actually has a 1939 truck, hope that helps.
Kregus #1333713 11/14/2019 3:20 AM
I am 99% positive the truck is a 46. Here is a few more photos. Unfortunately I have not been able to locate the serial number yet. I have heard it is stamped on the frame as well but I haven't gotten into that portion of it yet
Kregus
Lakewood, CO
Kregus #1333715 11/14/2019 3:56 AM
Well, that is for sure a '41 to '47.
Ed
Kregus #1333718 11/14/2019 4:42 AM
Forget looking on the frame, it is not there. Trucks of this era used the motor # for ID. The # is stamped on the flate plate next to the distributor. If you're lucky the original ID tag will be on on the right cowl panel. SEE PHOTO.
Harold
SHA1: 3736c61bf2d19f67cf9b5945df46175789e76822
Harold
Kregus #1333721 11/14/2019 5:36 AM
3B Offline
Hy Guys, that dash has been installed very crudely, look at all the screw heads all the way across the dash, it is definitely not the dash that cab left the factory with.
Kregus #1334305 11/19/2019 3:34 AM
I believe the cross shaped stamping in the firewall makes it a 1946.
