4 members (Otto Skorzeny, Johnny Rib, dwreills, 1 invisible), 95 guests, and 3 robots.
Topics128,036
Posts1,055,461
Members48,422
#1333658 11/13/2019 9:30 PM
the truck was running ok, started a little tough, but started. I replaced the generator with a 6 volt alternator, and it rear well too. I went to start if after being idle of few days, and. would not start. I replaced the battery with an Optima 6 volt, put on a 1/0. original cable and still won't start. I check and coil has power, I seem to have spark, the fuel filter l looks to have plenty of fuel, battery is fully charged- I am stumped. Starter is a little slows but better with a new cable adn battery- could it. be the starter??
thanks an any advice.
1948 3/4 ton Chevy Pickup
What size are your ground cables/straps (1/0 (0) or 2/0 (00) are good)?
Make sure your ground strap/cables connection points are good:
- battery to frame
- frame to clutch housing (I connect this one to a starter mounting bolt).
Cover all shiney/cleaned connection points with copper-impregnated anti-seize "grease" (sold in most auto-parts-stores in tubes or small jars.
this has been double-posted - one location (The Electrical Bay) is enough
sorry
