1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
Hi Everyone!
I'm working on my Grandpa's 1949 3100 and need to replace a spring on the original Carter YF carb. It's some kind of return spring toward the top of the bowl that affects the choke. We were having problems with the truck being unable to hold an idle and identified this spring as the culprit. However, I've been looking at all the online vendors and cannot seem to find a replacement spring. Attached is the photo of the spring I'm referring to.
Appreciate all the help and advice!
Alex
Go to the Parts Wanted forum and request the spring. Surely there are folks who have a bad Carter with a good spring.
Carburetion specialist
The 1949 would have had a Carter type W-1 as original. The Carter YF is a replacement.
Carter used a number of different springs. You will need the Carter identification number of the carburetor in order to acquire the correct spring.
Jon.
The Carburetor Shop
Which Carter YF model is it?
What spring?
I have a bucket of Carter YF parts.
Todd
1950 Chevy 3100
There are no bad Carters wink
Jon.
The Carburetor Shop
WOO HOO! I'm rich. Now I suddenly can't part with any of them. smile
Thanks John!
Hi Todd,
Need to double check the number on it when I get home from work today. Will post later. Thanks!
Alex, check your private message and let me know.
If I have it it's yours.
I can not count the number of Great people on this forum who have helped me during my build and continue to help me. Both with parts & WISE knowledge!
Todd
1950 Chevy 3100
Thanks Todd! Yeah - The amount of knowledge, history and mechanics I've learned from this site has been amazing! Couldn't have completed Grandpa's rebuild without all the help from the awesome folks on this forum!
